It is currently Fri Nov 22, 2019 4:29 am
 Post subject: Convert Byte into Array
PostPosted: Thu Jan 17, 2019 11:33 am
Hello all,
Have you got any ideas of how i can convert byte into an array in order to read and access to the datas ?
Thanks for your help
PostPosted: Thu Jan 17, 2019 3:09 pm
Byte into an bit array ? Then declare a union datatype with Byte and your bits (named into a DUT or in array)
PostPosted: Thu Jan 17, 2019 7:58 pm
I don't think that will work.
You can't make an array of BIT, and a BOOL occupies 8 bits, so it won't align.
There's probably an OSCAT block, but I can never find anything I want in OSCAT :)
I'd just:
Bit0 := (MyByte AND 16#1) <> 0;
Bit1 := (MyByte AND 16#2) <> 0;
Bit2 := (MyByte AND 16#4) <> 0;
PostPosted: Thu Jan 17, 2019 8:08 pm
A union would be nice but believe this doesn't work because of what Le_Baloo said. Been a while since I have tested it though.
What if you just use the UNPACK function. Input would be your byte and the output could tie each bit to your array.
https://help.codesys.com/webapp/unpack;product=codesys;version=3.5.11.0
Or you could do it by hand.
    BoolArray[0] := Byte.0;
    BoolArray[1] := Byte.1;
    BoolArray[2] := Byte.2;
    BoolArray[3] := Byte.3;
    BoolArray[4] := Byte.4;
    BoolArray[5] := Byte.5;
    BoolArray[6] := Byte.6;
    BoolArray[7] := Byte.7;
PostPosted: Fri Jan 18, 2019 10:05 am
So if you want to name it, declarations :
TYPE MyPumpCmd_STRUCT :
STRUCT
   Bit0 : BIT;
   Bit1 : BIT;
   Bit2 : BIT;
   Bit3 : BIT;
   Bit4 : BIT;
   Bit5_Run : BIT;
   Bit6_Reverse : BIT;
   Bit7_QuickStop : BIT;
END_STRUCT
END_TYPE
TYPE MyPumpCmd_UNION :
UNION
   aByte : BYTE;
   aStruct : MyPumpCmd_STRUCT;
END_UNION
END_TYPE
VAR_GLOBAL
   MyPumpCmd : MyPumpCmd_UNION;
END_VAR
Then, usage :
MyPumpCmd.Bit5_Run := TRUE
%OB5 := MyPumpCmd.aByte
EDIT 2019/01/21: Correct "Bit3 : BOOL;" to "Bit3 : BIT;"
PostPosted: Fri Jan 18, 2019 6:54 pm
Thanks dFx. I learned something new but there was one issue I ran into when testing this. When you specified BOOL for Bit3 it causes it to not work. All data types appear to have to be BIT in order for the union to work.
PostPosted: Mon Jan 21, 2019 10:41 am
Just a typo mistake. Edited my previous post.
BIT datatype is a bit length in memory, while BOOL is 8 bit length (a Byte).
