It is currently Tue Nov 19, 2019 1:26 am
PostPosted: Fri Dec 28, 2018 1:31 pm
I want to make a program for rasbperry pi using codesys such as it executes python scripts . So please can someone give me a simple example that I can follow?
PostPosted: Fri Dec 28, 2018 4:52 pm
if you want to execute them on the Raspberry PI,
by your IEC code, check this example here:
viewtopic.php?f=23&t=6247&p=19932#p19941
PostPosted: Fri Dec 28, 2018 6:01 pm
Edwin Schwellinger wrote:
Thank you!
I saw that post and I could not understand this line :
SysFileCopy('/var/opt/codesys/UHScroll.py', '/var/opt/codesys/PlcLogic/Application/UHScroll.py', ADR(dwCopySize));
What are these directories :
should I do exactly like that ?
PostPosted: Sat Dec 29, 2018 8:18 am
the python scripts are added as external file in your CODESYS project and with the CODESYS download
of your application they will be copied to '/var/opt/codesys/PlcLogic/Application/'.
The copy to '/var/opt/codesys/' is needed because this is the directory where the runtime could call the script ( path envirnment)
Sure if you do not need this, just copy your script to a location where the runtime could call it... and do not forget to enable
the command which you allow to execute by SysProcessCommand....
PostPosted: Sun Dec 30, 2018 12:34 pm
Thank you very much!
