Runtime User Managment and web-visu
e.kislov
2018-09-26
2018-11-05
  • e.kislov - 2018-09-26
    Hi.
    I use to Runtime User Managment to prevent access to PLC from CODESYS IDE without login/pass:
    https://help.codesys.com/webapp/_cds_ha ... n=3.5.13.0
    All is fine, but together with that I need to enter same login/pass when I open web-visu page. It's unwanted for me.
    How I can use runtime user managment only for CODESYS IDE access, but not for web-visu access?
  • e.kislov - 2018-09-30
    Any ideas, friends?
  • m.prestel - 2018-10-30
    Hello sir,
    this issue should hopefully be fixed with SP14 (but only if you have file access disabled)
    Best regards,
    Marcel
  • e.kislov - 2018-10-30
    m.prestel hat geschrieben:
    Hello sir,
    Best regards,
    Marcel
    Thanks for info.
    What you mean under "file access disabled" ?
  • m.prestel - 2018-11-02
    Hello sir,
    having set to 1 will still require a login (which is not the case for most of the runtimes anyway).
    Best regards,
    Marcel
  • e.kislov - 2018-11-02
    Hello sir,
    Best regards,
    Marcel
    In this case I need to enter login/pass only after click to element with InputConfiguration - Transfer File?
    Or (as before) when I open web-page?
  • m.prestel - 2018-11-05
    Hello sir,
    no you will have to enter the passwort as before.
    However we still plan to provide a better solution for this as well!
    Best regards,
    Marcel
  • e.kislov - 2018-11-05
    Hello sir,
    Best regards,
    Marcel
    Thanks, I'm glad to hear it, because use visu transfer files (AllowFileTransferServices=1 in my case).
