i am looking for information about persistent variables. I made a program which declare some persistent variables. Everything work fine and when the device shutdown and restart, the variable are indeed persistent in the right way. When i change the program (not the PersistentVars) and upload the new program to the device, the persistent variables are not restored as expected : not always, depending on the modification i made to the programe.
I had try a lot a things but do not understand why when i made a change to the program, sometime the persistent variables restart from 0 (persistent lost) and sometime the persistent variables keep its latest value. When exporting in OpenXML, i saw that sometimes tags "Checksum_Type" and "checksumnoinit_override" are added.
Does someone can help me understand if this behaviour is correct or not ? Does someone know the meaning of the tag "Checksum_Type" and "checksumnoinit_override" ?
which device and which version are you using?
If the retain/persist vars do not work reliable try to solve the root cause... there is not need to Workaround
by any XML file ( even I think this is not possible)
<attribute name="Checksum_Type" value="3401061445"></attribute>
<adddata>
<data handleunknown="implementation" name="http://www.3s-software.com/plcopenxml/attributes">
<attributes>
<attribute name="checksum_override" value="2196742183"></attribute>
<attribute name="authentification" value="d433c4d1-208a-4b7a-b4ba-e3c77e67e46b">
<attribute name="vfinitonly" value="">
<attribute name="dummy" value="0">
<attribute name="checksumnoinit_override" value="2363421397"></attribute>
</attribute></attribute></attribute></attributes>
</data>
</adddata>
This forces your value when downloading with rebuild all.
Just don't rebuild all, or update your initial values.
Thank. Do you know if there is some documentation about these XML tags ?
