It is currently Tue Jan 28, 2020 1:24 am
 Post subject: codesys3 data logger
PostPosted: Sat Oct 27, 2018 11:57 pm
I am trying to create a codesys3 data logger, any recommendations?
The library AC_DataLog may be useful but can't find how to use it examples.
still struggling importing OSCAT Network library 1.2.1.1. I have it in the library manager but the compiler doesn't allow me to use it yet. I can see the data type ex "DLOG_DATA" in the library but shows, as not defined when I try to, used it.
 Post subject: Re: codesys3 data logger
PostPosted: Wed Oct 31, 2018 10:17 am
Actually, to datalog, I use a simple FIFO in a huge array of whatever. (usually one or more value and a timestamp in a structure).
If the datalog has to be huge, you may save CPU time using rotating start/end index instead of moving data.
PostPosted: Wed Oct 31, 2018 9:56 pm
I am also very interested in a generic datalogging solution!
A store and forward combined with an RTC generated timestamp (of that old event) in combination with OPC UA is prefered.
PostPosted: Sun Nov 04, 2018 8:20 am
this should point you in the right direction I guess:
https://help.codesys.com/webapp/ac_dlm_ ... n=3.5.13.0
For using the AC-data logger no extra license is needed.
You could choose to log into an csv file or sqlite db.
PostPosted: Tue Jul 09, 2019 1:31 pm
hi i am interested by the datalog functions too,
but i do not understand how to add my logging variables
PostPosted: Wed Jul 10, 2019 1:54 pm
I marked variable by {ac_datalog[:=DataLogChannel]}, but this didn't work. Has anyone have example how to use AC_DataLog?
PostPosted: Wed Jul 10, 2019 2:53 pm
attached an example project:
PROGRAM PLC_PRG
VAR
    timer : Standard.TON;
    {attribute 'ac_datalog_hysteresis' := '1.745'}
    {attribute 'ac_datalog' := 'DataLogChannel'}
    iLogVar : INT;
    rLogVar : REAL;
    {attribute 'ac_datalog_hysteresis' := '0.745'}
    sLogVar : STRING := 'Hallo';
    //{attribute 'ac_datalog' := 'DataLogChannel'}
    arLogArray : ARRAY[0..4] OF REAL;
    {attribute 'ac_datalog_set_default_group' := 'DataLogChannel'}
    instStruct : LogStruct;
    {attribute 'ac_datalog_union_set_representant' := 'uiLog'}
    {attribute 'ac_datalog' := 'DataLogChannel_1'}
    instUnion : LogUnion;
    {attribute 'ac_persist' := 'PersistenceChannel'}
    instFB : POU_Log;
    iLogVar2 : INT;
END_VAR
timer(IN := TRUE, PT:=T#5S);
IF timer.Q THEN
    iLogVar := iLogVar + 1;
    iLogVar2 := iLogVar;
    timer(IN := FALSE);
    rLogVar := arLogArray[2];
    instStruct.bLog := instStruct.bNoLog;
    instFB.Prop_Log := instFB.Prop_Log + 1;
END_IF
Keep in mind that extensive cyclic data writings will kill your storage device ( so handle with care what and where to save these data)
Cheers
PostPosted: Wed Jul 10, 2019 7:40 pm
Nice,
The attached project works like a charm. Thanks!!
This brings ups some questions;
* Can the PLC itself now visualise the stored Sqlite db / CSV information? So showing the contents of the db/csv in a trend or trace by design with a local history :D
* Ideally the PLC pushes the stored information after some trigger to a "consumer". Is there a way to facilitate this?
If not, any other ideas on achieving such a scenario are very welcome!
I would like to hear any thoughts on this, as the example shows how to save the data in a neat way but it does not show how to retrieve or send it.
PostPosted: Thu Jul 11, 2019 9:21 am
is this datalogger can be used for 100ms data log ?
