It is currently Tue Jun 25, 2019 8:34 am
 Post subject: DSP402 Axis parameters
PostPosted: Mon Oct 01, 2018 3:32 pm
Hi everyone,
Is there a way to set the values of the DSP402 related parameters in ST?
Thank you in advance,
Omar
PostPosted: Mon Oct 01, 2018 8:58 pm
Axis_ref_sm3 has a lot of parameters declared as var_input. You can read or write them directly as fpositionfactor or settotorque....
PostPosted: Tue Oct 02, 2018 7:43 am
Hi Josep,
Unfortunately the parameters in an Axis.DSP402_Statemachine (axis of type AXIS_REF_ETC_DS402_CS) are not inputs, the compiler won't allow you to write them.
These parameters can be changed in the device editor but I would like to have their parametrization in ST.
Regards,
Omar
PostPosted: Tue Oct 02, 2018 8:36 am
Hi.
Axis_ref_etc_ds402.... Extends from axis_ref_sm3. It has the same variables as _sm3 and any others. (I recomends to you to treat the axis as sm3 it make your code more portable).
My axis_ref is axis_ref is etc_ds402... Too.Image
PostPosted: Tue Oct 02, 2018 2:11 pm
Hi Josep,
Still your example does not work for the parameters related to the DSP402_Statemachine, they cannot be accessed in the same way as in your example.
Regards,
Omar
PostPosted: Tue Oct 02, 2018 4:50 pm
Hi
What do you want to do?
StateMachine is an enum which is controlled by the axis and change when you give orfers to the axe.
PostPosted: Wed Oct 03, 2018 2:03 pm
Hi Josep,
I am taking about these parameters (see attached).
Regards, Omar
PostPosted: Mon Oct 08, 2018 8:14 am
This is not a canocical form, but works:
PostPosted: Tue Oct 09, 2018 7:43 am
GrĂ cies Josep :D. I'll try it out.
Regards, Omar
PostPosted: Thu Oct 18, 2018 8:40 am
It works thank you!
Gr, Omar
