It is currently Tue Oct 15, 2019 6:07 pm
PostPosted: Wed Sep 05, 2018 1:58 pm
Hello
Trying to install the CODESYS Control for PFC100 SL i get error messages. Anyone know what could be the problem/solution?
PostPosted: Sun Sep 09, 2018 6:58 am
never seen, which firmware is this,what happens if you install it by login by ssh and:
ipkg install codesyscontrol_arm_pfc200_V3.5.13.x.ipk
PostPosted: Thu Sep 13, 2018 10:33 am
Hello
I am using this package: codesyscontrol_arm_pfc100_V3.5.12.40.ipk
Using ssh I get the same error:
root@PFC100-416D28:~ ipkg install codesyscontrol_arm_pfc100_V3.5.12.40.ipk
ipkg: *** Couldnt kill old gunzip process *** aborting
If I log into the web interface of the PLC I get the 3S interface and not the wago Interface, It seems like it might be installed.
If I scan for PFC100 in the PFC100 phane in codesys I find it.
If I scan for the device in my project i don't find it.
If i try to start the Runtime using the start button in the PFC100 phane in codesys I get an error message..
See attached photos.
PostPosted: Thu Sep 13, 2018 2:52 pm
Installation is ok,
just add a Gateway with the IP of the PFC100. Switch to this new Gateway, then you will find the PFC100 by the scan.
PostPosted: Fri Sep 21, 2018 10:56 am
Hello, thank you for the reply.
Adding a gateway with the IP of the PLC does not help. I get this error message.
PostPosted: Sat Sep 22, 2018 6:14 am
could you Login by ssh (putty for example) and call
top
or
cat /tmp/codesyscontrol.log
to chek if the runtime is running?
PostPosted: Tue Sep 25, 2018 1:32 pm
Hello
codesyscontrol.log is not found,
PostPosted: Tue Sep 25, 2018 3:02 pm
your screenshot say you are using Firmware(09) Version,
I would update to current Version ( request on Wago homepage for the new Firmware 11)
Boot with it from micro sd and update your Firmware by WBM in the browser...
