I Have Discovered Issue(not really but its not good too) In Old Code That,
IF Any one of the Variable is Changed
THEN writetable :=True
it means Every single time it will go and write value in table, I want to improve that in some better way.
If Any one Could suggest Anything it will be great.
Thank You
one possibility would be to use a FOR loop and Arrays. Something like this:
VAR  mParameter:ARRAY[0..ArrayLength]OFINT:=[1,2,3,4,5];  pParameter:ARRAY[0..ArrayLength]OFINT:=[1,2,3,7,5];  counter:INT;  writetable:BOOL;END_VARVARCONSTANT  ArrayLength  :INT:=4;END_VAR
FORcounter :=0TOArrayLengthDO
  IFmParameter[counter] <>pParameter[counter] THEN
    writetable :=TRUE;
    EXIT;
  END_IFEND_FOR
Anonymous
2018-09-20
Originally created by: Viacheslav Mezentsev
Struct + pointer + mem utils + crc.
I'd go with a crc approach as this is way more flexible with regards of your array/tablesize.
If the current crc (of your table) differs from the newly calculated crc then you trigger the writing of the table.
The example @Viacheslav Mezentsev demonstrates this mechanic.
Hello ,
Thank You
Please explain your purpose/problem a bit more, some more information on what you are trying to achieve would be welcome
hello Aliazzz,
I explain The problem here :
if at least one parameter changes, send parameters table to Database
IF( (
mParameter1 <> pParameter1 OR
mParameter2 <> pParameter2 OR
mParameter3 <> pParameter3 OR
mParameter4 <> pParameter4 OR
mParameter5 <> pParameter5 ))
THEN
writetable := TRUE;
END_IF
Thank You,
