I am trying to parametrize an AXIS_REF_SM3 subtype not via the GUI but via IEC code. Do I have to use the fb SMC3_WriteParameter for this? If yes, what is the difference between using that fb and simply assign a value, for example:
rclsAxis.fPositionPeriod:= 360.0;
There are also some parameters such as ScalingIncs, ScalingMotorTurns1, ScalingMotorTurns2 etc which I can't find inside the axis structure. I checked the device description xml and these parameters have a parameter ID but I am not sure whether they belong to the axis? Can fb SMC3_WriteParameter also be used for writting these parameters?
Thank you in advance,
Omar
Hi everyone,
Omar
