Close dialog with Visu Utils
e.kislov
2018-08-16
2021-11-15
  • e.kislov - 2018-08-16
    With Visu Utils library it's very easy to open dialog from code.
    But how I can close it with this library?
  • e.kislov - 2018-08-20
    Edwin, hope on your advice.
    I need something like that:
    IMG: 20
  • e.kislov - 2018-08-24
    Any ideas?
  • Lo5tNet - 2018-08-24
    I have not used visu utils but this is how I have closed dialogs in the past using this function:
    This function needs to be called from the same task as your VisuElems.Visu_Prg
    We had a button that set the PLC_PRG.xCloseDialog to TRUE
    My understanding is you can't use the "CurrentVisu" Variable when using this. Hope this helps a little.
    IMG: CloseVisuDialog.PNG
    IMG: CloseVisuDialogCall.PNG
  • e.kislov - 2018-08-25
    Thanks, it's seems like a solution.
    Your function is not use sDialogName (so it works as "CloseAllDialogsForAllClients"), but I understand how I should edit code for my task.
    I'm very appreciated.
    I hope 3S include same FB in Visu Utils in next SP's.
  • MaraP - 2018-08-27
    Does anyone knows if this works also in TwinCat 3?
  • Lo5tNet - 2018-08-27
    You are correct e.kislov and sorry about that. Was a solution for something else we were experimenting with. To do a specific dialog you would change it to this:
    IMG: CloseVisuDialogByName.PNG
    • nyoman123 - 2021-11-15
      Hello, I'm quite new to codesys do you have a code example like this for opening dialog?
      Thank you
  • Nico01 - 2019-08-07
    Vielen dank.
    It works very well under TwinCat3.
    tschΓΌss
