I'm currently working in SM3_Basic, 4.3.2.0 and control the axis in CiA402 axis.
For the FB "MC_TouchProbe", I could only get a single measurement function.
But most of the modern ethercat servo drive support permanent measurement(usually set Touch Probe Function control word bit 1 := 1) which means execute edge activates function until abortion by MC_AbortTrigger. I have tried to modify the Touch Probe Function control word in the program through direct access the address, but it is not changed. Is there any other way I could do this?
Any comment/ advice is appreciated and thanks in advance.
James
Hi~
James
Hi James,
hm.. you could remove the Objects from control word /pdo data and use SDO's to start the touchprobing manually.
Not nice but maybe works..
