It is currently Sun May 26, 2019 2:10 pm
PostPosted: Fri Jul 13, 2018 9:36 am
hello just like to ask if anyone is loosing visualization after sometime im test running rpi 3B and rpi 3B+ both are running but after awhile i cant connect visualization address but ask for checking the network connection its still up i can send command via SSH i can reboot the RPI after reboot i can access again the Visualization hope anyone could help thanks
PostPosted: Fri Jul 13, 2018 6:31 pm
Do you loose connection after 2 hours of it running?
PostPosted: Sat Jul 14, 2018 8:41 am
im not sure of the time but ive try to run 2 RPI one with sense hat one with raw RPI both lost connection after sometime as for checking they are still on the network i can connect via SSH and run commands but the codesys software cant connect also the visualization is lost
PostPosted: Sun Jul 15, 2018 7:13 am
which Version is this?
If you lose the connection ist the plc still running ( check by ssh - top )
There have been a bug on Versions < 3.5SP12 that communications channels are lost.
PostPosted: Mon Jul 23, 2018 6:17 am
got the problem i was unable to verify the license online thanks for the help
