hello just like to ask if anyone is loosing visualization after sometime im test running rpi 3B and rpi 3B+ both are running but after awhile i cant connect visualization address but ask for checking the network connection its still up i can send command via SSH i can reboot the RPI after reboot i can access again the Visualization hope anyone could help thanks
im not sure of the time but ive try to run 2 RPI one with sense hat one with raw RPI both lost connection after sometime as for checking they are still on the network i can connect via SSH and run commands but the codesys software cant connect also the visualization is lost
If you lose the connection ist the plc still running ( check by ssh - top )
There have been a bug on Versions < 3.5SP12 that communications channels are lost.
Do you loose connection after 2 hours of it running?
which Version is this?
got the problem i was unable to verify the license online thanks for the help
