It is currently Tue Jun 25, 2019 4:39 pm
Post new topic  Reply to topic  [ 18 posts ]  Go to page 1 2 Next
 Post subject: MQTT
PostPosted: Tue May 29, 2018 8:45 pm
Hi there!
I did implementing an MQTT library, test it an have fun…
Greatings
Short info from short doku...:
Quote:
Hello There,
with this library you are able to send and recvice MQTT paket on all QoS levels 0-2.
Use Pubish to publish data(Strings and binary),
Use subscribe to recive MQTT data. On Subscribe you can tell the FB if you are expecting an String as data, so you will get one on the pointer output.
How to use you can see n de TestMqtt FB. This is my Test Case an it does up to 100 send and recives per second on an raspberry PI 1+ connectet to an mosquitto broker on an
windows 10 maschine.
If you find errors, or anny instability, tell me, i will have a look.
I started to implement TLS, but this will take a wile, so don't care about the TLS and crypto errors.
This Projekt i using some parts of the grat OSCAT libs, so take a look at oscat.de
Stefan
MQTT.projectarchive
 Post subject: Re: MQTT
PostPosted: Wed May 30, 2018 10:27 pm
Would you be so kind and repost the projectarchive again?
> but this time be sure to add "CmpCrypto" v3.5.11.0 compiledLibrary
I can't seem to download this missing lib from the codesys store, so the projectarchive will not compile.
Many thanx in advance!
(Scroll down for my projects)
PostPosted: Wed May 30, 2018 11:25 pm
Hi Aliazzz,
This CmpCrypto Lib is missing on my System too. I can Add it in My Librarymanager, but it isn't resolved.
So, how i write in the first post
Quote:
I started to implement TLS, but this will take a while, so don't care about the TLS and crypto errors.
This is a Problem i need to solve for the TLS implementation im working in.
On my System ist working without.
Greetings Stefan
PostPosted: Thu May 31, 2018 7:19 am
Hi!
Did some improvements and added some coments, CmpCrypto error is gone…
have fun…
Stefan
MQTT.projectarchive
PostPosted: Fri Jun 01, 2018 9:28 am
Good work, thank you!
PostPosted: Thu Jun 21, 2018 1:47 pm
Hi Stefan,
i have the same Problem with my PLC Program, could you tell me please how you solved the Problem of the CmpCrypto?
Thank you very much !
Hani
Stefan2 wrote:
Hi!
have fun…
Stefan
MQTT.projectarchive
PostPosted: Mon Jul 09, 2018 11:11 pm
Hello Hanels,
i just deleted the TlcCmp Lib, i go Forward, TLS is now supporte by my lib, but still i have to do much.(Long Topics and payloads)
The Error first disapears when the lib is link on an runtime System, i don't know why, i think the linking to OpenSSL works only if the Runtime System in known.
Bye
Stefan
PostPosted: Tue Jul 10, 2018 12:48 pm
Hey Stefano,
thanks for the publish.
Could you please make it available on github? So we could help you with TLS integration. I think this would be a great community project.
cheers,
KevinR
PostPosted: Tue Jul 10, 2018 11:00 pm
Hello Kevin,
TLS implementation is already done, works fine to test.mosquitto.org.
but i still improving the lib to be able to use Topics up to 64kB an Payloads up to 200MB....
i am glad about your offer to help, i am going to think about it.
for this i Need to have a github account, but this shouldn't be the Problem.
Bye
Stefan
PostPosted: Wed Jul 11, 2018 9:16 am
Hello Stefan,
If TLS is already implemented is it possible to use also own registered cert?
Let me know if you need some help. I also can do some tests.
BR,
Kevin
PostPosted: Wed Jul 11, 2018 5:14 pm
Hello Kevin,
no, certification is not implemented yet. But should be no problem.
when i am further with the lib i tell you.
And i have a gibhub account now...
Stefan
PostPosted: Sat Jul 21, 2018 8:40 pm
Count me in if you post your code in github ..
The newly posted Crypto Example should help out also
PostPosted: Tue Jul 31, 2018 12:43 pm
now all needed Projects are on GitHub. TLS and MQTT are now splittet, i am going on to work on MQTT further.
If you like to ad certificates, you Need to work on CommonTypesAndFunctions, there is an FB IP_CONTROL. This on supports TLS without certificates, take al look on testmqtttls in MQTT.libraray, this works with test.mosquitto.org.
Changing the interface is not longer needed, just extend TLS_CONFIG in CommonTypesAndFunctions.
I would like to see an string were i can give an name of an certificate installed with the Security Manager of CODESYS which then is used by the Connection. Take a look and tell me what you think
Stefan
PostPosted: Tue Jul 31, 2018 12:56 pm
i forgot, please start here:
https://github.com/stefandreyer
Stefan
PostPosted: Wed Aug 01, 2018 12:08 pm
sorry, i meant that i would be happy if it can Beo solved this way…
Stefan
