hello, I have a raspberry card and I manage two Controllino maxi for home automation management with codesys.
The two controllers are connected in modbus slave and work great.
On the same network I then have another raspberry, located in the room, which I use as a magic mirror.
Now I would like to be able to control the air conditioner and detect the temperature with that raspberry.
To do this, do I need to install a codesys license on this raspberry too?
Thanks, Alberto
hi all, how can I make a raspberry a tcp modbus slave?
I already have a raspberry with codesys so I would like to connect a simple raspberry with modbus tcp slave protocol and check it from codesys
Thanks, Alberto
Good evening, I managed to connect a remote raspberry with pymodus with the following code.
frompymodbus.server.asyncimportStartTcpServerfrompymodbus.deviceimportModbusDeviceIdentificationfrompymodbus.datastoreimportModbusSequentialDataBlock,ModbusSlaveContext,ModbusServerContextimportRPi.GPIOasGPIOimportosos.system('modprobe w1-gpio')os.system('modprobe w1-therm')
\#set up Raspberry GPIO defmain():    store=ModbusSlaveContext(    di=ModbusSequentialDataBlock(0,[0]*100),    co=ModbusSequentialDataBlock(0,[0]*100),    hr=ModbusSequentialDataBlock(0,[0]*100),    ir=ModbusSequentialDataBlock(0,[0]*100))  context=ModbusServerContext(slaves=store,single=True)  identity=ModbusDeviceIdentification()  identity.VendorName ='pymodbus'  identity.ProductCode='PM'  identity.VendorUrl  ='http://github.com/simplyautomationized'  identity.ProductName='pymodbus Server'  identity.ModelName  ='pymodbus Server'  identity.MajorMinorRevision='1.0'  StartTcpServer(context,identity=identity)#, address=("localhost", 502))if__name__=="__main__":  main()
Now I would like to map the outputs and the gpio revenue into codesys.
In particular I would like to read the value of a probe ds18b20 connected to that pi.
Do you help me insert the python code and map the exit in codesys?
Thanks, Alberto
Hi guys, I'm almost straight for arrival but I still miss what little that makes me sleep.
Below I put the code that must run on the PI on which pymodbus runs.
importtimeimportargparseimportsys,tracebackimportthreadingimportRPi.GPIOasGPIOimportsmbusimportsubprocessimportpymodbusfrompymodbus.server.asyncimportStartTcpServerfrompymodbus.deviceimportModbusDeviceIdentificationfrompymodbus.datastoreimportModbusSequentialDataBlockfrompymodbus.datastoreimportModbusSlaveContext,ModbusServerContextfrompymodbus.register_read_messageimportReadHoldingRegistersResponsefrompymodbus.client.syncimportModbusTcpClientfrompymodbus.server.syncimportModbusTcpServerglobalserverglobalipdefServerThread(e):  globalserver  # Configure the service logging  #import logging  #logging.basicConfig()  #log = logging.getLogger()  #log.setLevel(logging.DEBUG)  # Initialize your data store  store=ModbusSlaveContext(    di=ModbusSequentialDataBlock(0,[0]*100),    co=ModbusSequentialDataBlock(0,[0]*100),    hr=ModbusSequentialDataBlock(0,[0]*100),    ir=ModbusSequentialDataBlock(0,[0]*100))  context=ModbusServerContext(slaves=store,single=True)    # Initialize the server information  identity=ModbusDeviceIdentification()  identity.VendorName ='Pymodbus'  identity.ProductCode='PM'  identity.VendorUrl  ='http://github.com/bashwork/pymodbus/'  identity.ProductName='Pymodbus Server'  identity.ModelName  ='Pymodbus Server'  identity.MajorMinorRevision='1.0'  # Run the server  server=ModbusTcpServer(context,identity=identity,address=(ip,502))  print("Server started")  server.serve_forever(0.1)  print("Server stopped")defClima(update_interval,e):    #Gestione del climatizzatore  print("Clima")  client=ModbusTcpClient(ip)  whileTrue:        rr=client.read_holding_registers(0x000A,1,unit=UNIT)        assert(rr.function_code<0x80)   # test that we are not an error        ifrr.registers[0]==1:            subprocess.call(["irsend","SEND_ONCE","AnalysIR","ACCENDI"])            #print (cmd)            time.sleep(0.01)            client.write_register(0x0008,100)#VERIFICA        elifrr.registers[0]==2:            subprocess.call(["irsend","SEND_ONCE","AnalysIR","SPEGNI"])            #print (cmd)            time.sleep(0.01)            client.write_register(0x0008,0)#VERIFICA        elifrr.registers[0]==3:            subprocess.call(["irsend","SEND_ONCE","AnalysIR","MODO_VENTILATORE"])            #print (cmd)            time.sleep(0.01)            client.write_register(0x0008,101)#VERIFICA          break        client.close()print("Clima thread stopped")defTemperatureUpdateThread(update_interval,e):    #Scrivo la temperatura nel registro 0x0000  print("TemperatureUpdateThread")  client=ModbusTcpClient(ip)  whileTrue:    ifnote.isSet():      tfile=open("/sys/bus/w1/devices/28-0117c15d88ff/w1_slave")      text=tfile.read()       tfile.close()      secondline=text.split("\n")[1]      temperaturedata=secondline.split(" ")[9]      temperature=float(temperaturedata[2:])      client.write_register(0,temperature)      print(temperature/1000)      time.sleep(update_interval)    else:      break  client.close()  print("Temperature 0 sensor thread stoped")if__name__=="__main__":  globalserver  globalip  print("=== Modbus Device ===")  parser=argparse.ArgumentParser(description='Modbus server')  parser.add_argument('ip', default='localhost',help='IP adress of modbus server')  args=parser.parse_args()  ip=args.ip    e_exit=threading.Event()    thServer=threading.Thread(name='ServerThread',target=ServerThread,args=(e_exit,))    thTemperature=threading.Thread(name='TemperatureUpdateThread',target=TemperatureUpdateThread,args=(1,e_exit,))    thClima=threading.Thread(name='Clima',target=Clima,args=(1,e_exit,))    UNIT=0x01      # Init hardware    GPIO.setmode(GPIO.BCM)    GPIO.setwarnings(False)  thServer.start()  time.sleep(1)    # Start clients  time.sleep(1)  thTemperature.start()    time.sleep(1)    thClima.start()      # Wait for keyboard interrupt  try:    whileTrue:      time.sleep(1)  exceptKeyboardInterrupt:    print("Stopping program")  exceptException:    traceback.print_exc(file=sys.stdout)  # Set stop event for clients  e_exit.set()  # Shutdown server  server.shutdown()  # Wait until server shutdown  whilethServer.isAlive():    time.sleep(1)      # Clean up  GPIO.cleanup()      # Stop the program  print("Done")  sys.exit(0)
With this code I send on codesys the value of the temperature from the ds18b20 and contains code that controls the air conditioner.
For the temperature everything is ok.
The problem is with the commands to the air conditioner.
The Climate thread works as it is but with a small but important flaw.
When executing last command, elif leaves the thread
I'm not familiar with Python, and by copying / modifying this piece of code found on the internet I understand that python uses indentation as terminators.
Now I can not figure out how to fix this my little / big problem.
Thanks, Alberto
Thanks, Alberto
you only need the Raspberry PI runtime license (no additional modbus license)
here in the Pi application section in this Forum is an example project for doing this:
l viewtopic.php?f=21&t=6884 l
Modbus project with 2 Pi's.
But I thought it was like with arduino.
Install the pymodbus library on raspberry and check it from codesys as in arduino.
Thanks, Alberto
.... I'm almost there.
I read the ds18b20 on codesys !!
I just need to be able to control the heat pump on that raspberry and I finished
Well, I've decoded the infrared remote control for the heat pump and managed by python.
Now I just have to put everything together on codesys
Can you help me?
Thanks, Alberto
Related
Talk.ru: 1
