Hi is there some possibility to skip some part in code during compiling code. Based on if with Constant value?
Something like this in C#. I've found pragmas in CODESYS, but my idea is that based on constant value will be called certain lines of code.
C#
\#ifDEBUG
Β Β Console.WriteLine("Debug version");
\#endifPossibilityinCODESYS?
VAR
Β Β diNumber: INT;END_VARVARCONSTANT
Β Β iDebug:INT:=1;END_VAR//incasethatiDebugis2wholecodeisskippedincompilation
{IFhasvalue(iDebug,1)}
(*Β thefollowingcodeisonlyprocessedinApp1*)
{info'value is 1'}
getnumberofadapters(ADR(diNumber));y :=1;
{ELSIFhasvalue(iDebug,2)}
(*Β thefollowingcodeisonlyprocessedinApp2*)
{info'value is 2'}
y :=2;
{ELSE}
{info'value is none'}
y :=3;
{END_IF}
Reason why I'm asking is that in some PLC is unsupported some library and I want to avoid error during download such as unresolved reference to getnumberofadapters
