It is currently Tue Oct 15, 2019 6:27 pm
PostPosted: Thu Jan 04, 2018 12:43 pm
I am using a trend recording widget with BBB. Most of the time it works fine, but sometimes, it crashes after a "Reboot Target".
The exception error happens in DeterminePreviousConfiguration [TrendFBColumnManager].
To fix this issue, I need to delete the sqlite databases.
I have attached a sample project.
supervision_minimalCrashExemple.project
If you run it on a BBB, then restart the target, it sometimes crashes. I noticed it was often linked with a few changes I make on the project, for example, structured code modifications or adding control widgets, then somehow project is not properly updated even with full uploading of the new project.
Anthony
PostPosted: Tue Jan 09, 2018 5:32 am
thank you for reporting this,
I have created a Bug report for this.
Hope this will be solved in one of the next Versions.
