It is currently Fri Feb 22, 2019 5:27 pm
PostPosted: Tue Dec 05, 2017 2:42 pm
We have a pc with intel 82579 ethernet controller , and it is not on the supported list.
Will it work , not work or do we just need to try/test it ?
supported:
Systems with Windows and CODESYS Control RTE (Real-time SoftPLC):
Realtek 8139 (CmpRTL81x9Mpd)
Realtek RTL8139 and compatible Ethernet-Controller, as well 8100/8110
Realtek 8169 (CmpRTL8169Mpd)
Realtek 8169/810, RTL8111B / RTL8111D
Intel EtherExpressPro1000 (CmpEt1000Drv)
Intel 82541, 82547, 82567,82571, 82573, 82574, 82583V, i210, i217-LM etc.
Intel EtherExpress PRO/100 (CmpEt100Drv)
Intel 82551, 82557, 82559, 82559, 82558, 82557, 82550
PostPosted: Tue Dec 05, 2017 7:42 pm
it should work,
if not we need to make it work.
Could you give this a try and give us the feedback?
PostPosted: Fri Dec 08, 2017 5:15 pm
Edwin,
Will "Intel® I210IT PCI-E Gigabit LAN" controller work for EtherCAT?
Kumar.E
PostPosted: Sun Dec 10, 2017 1:08 pm
Edwin,
can not get it working.
I have beckhoff TC2 installed , so first I removed the Twincat Intel PCI ethernet adapter and uninstalled TwinCat2
restart
then the intel 82579 comes up as networkadapter and I removed it.
at first could not find the right inf file , but found it on reinstall date in oem 4.
removed oem4.inf and oem4.pnf
restart
then it comes up with unindetified hardware and i go to the driver location.
but it indicates that no valid driver for this hardware is found.
i found the drivers in windows /system32/drivers. (CmpEt100drv.sys CmpEt1000Drv.sys)
that is different from the location that is in the documentation <RTE-installation directory>\cmpet1000 but are the right ones i think.
Had to do system recovery at this point because ethernet was not working any more.
can you help me to get it working.
it is a XP sp3 windows 7 PC
PostPosted: Sun Dec 10, 2017 1:51 pm
which Version are you using exacly?
.. so what XP or Windows 7?
PostPosted: Mon Dec 11, 2017 7:45 pm
windows 7 home premium sp1
PostPosted: Mon Dec 11, 2017 7:52 pm
is this current RTE Version?
3.5SP11Patchx?
Could you give me the following Information from your nic?
PostPosted: Tue Dec 12, 2017 6:07 am
edwin,
3.5.11 .4
PCI\VEN_8086&DEV_1502&SUBSYS_047E1028&REV_04
PCI\VEN_8086&DEV_1502&CC_020000
PostPosted: Tue Dec 12, 2017 11:29 am
please use attached net541ex.inf and copy it to:
C:\Program Files\3S CODESYS\CODESYS Control RTE3\CmpEt1000MPD
then point on the Windows driver installation to this file.
Let me know if this works for you.
PostPosted: Thu Dec 14, 2017 1:27 am
kumareasu wrote:
Edwin,
Kumar.E
Edwin,
regards,
Kumar.E
PostPosted: Thu Dec 14, 2017 7:17 am
works. thanks. :-)
the same file was already in the map . That one didn,t work.
Replaced it by the one you send and that worked.
Need RTE for distributed clock for the drives. The drives otherwise go in error because of the jitter if i use codesys control
Had to remove beckhoff twincat 2 otherwise it keeps installing the twincat intel DCI ethernet adapter.
What happens if I reinstall beckhoff twincat 2 or 3. It overwrites the driver again i think.
not i good idea, but I need twincat also to set basis parameters for the ax drives an other beckhoff devices.
Must use 2 pc,s one for codesys, one for beckhoff . any tips?
regards
Han
PostPosted: Thu Dec 14, 2017 8:48 am
Hi Kumar.E
yes should work too.
If the vendor id is not in the inf file add it an please let me know
PostPosted: Mon Dec 18, 2017 6:20 am
Edwin ,
still have 10 unresolved references on login:
sysethernetadapterclose
getnumberof adapters
getadapterinfo
sysethernetadapersopen
sysethernetadaptersframesend
sysethernetadaterframe release
getipethernetframe
syethernetframe send
sysethernetipframereceive
ethernet adapter is installed :codesys ethernetExpress gbit pci ethernet adapter
I think still error regarding the ethernet driver ??
any advice?
PostPosted: Mon Dec 18, 2017 8:29 am
check the Control RTE Manual.
And since 3.5SP12 there is Control RTE and Control Win in the online help:
https://help.codesys.com/webapp/_cds_rt ... n=3.5.12.0
you need to add the component in the RTE configuration.
That will solve it
PostPosted: Thu Dec 28, 2017 3:27 pm
Edwin,
Ok, it is working now.
forgot the driver in the component manager.
thankx
