It is currently Sun Jan 19, 2020 11:34 am
Post new topic  Reply to topic  [ 59 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Fri Oct 03, 2014 3:57 pm
very good, seems to work reliable.
PostPosted: Sat Nov 01, 2014 9:12 am
hi
I have been breaking the sd card several times, the solution seems very good, doing this, we would already be enabled Retain variables ?.
Could someone put an image with condiguracion sd read only?
Thank you.
Greetings.
PostPosted: Wed Apr 19, 2017 11:51 am
I have several problems when the app is running for long time:
After two hours:
-I haven't trend. I tried to change the directory and configuration, always the same error.
After four hours:
- It can´t write log in Pendrive or SD. Error= NO_EXIST but i can see the directory and files with VNC. My personal log was running by 4h no more.
- I haven't IPv4 and I can't access to Webvisu form Browser.
- I add a screenshot of the log.
Thank you very much to everyone for your help.
PD. The license was check and ok (yellow light)
Hector.
PostPosted: Thu Oct 26, 2017 1:36 pm
Just put my raspy in read only mode. Instead of a usb drive i created a 3rd partition and followed the instructions of Mr. Schwellinger.
Unfortunally i get a licence error for the Profinet Interface (Screenshots after Download, not started!)
Can somebody help me pls...
Regards.
PostPosted: Thu Oct 26, 2017 1:55 pm
still searching in /etc/CODESYSControl.cfg (see screenshot), although i modified the /etc/init.d/codesyscontrol:
do_start () {
        make_mknod
        export PlcConfigFile=/media/CODESYSControl.cfg
        if [ -d "/sys/bus/platform/drivers/bcm2708_i2c/" ]; then
                echo bcm2708_i2c.0 > /sys/bus/platform/drivers/bcm2708_i2c/unbind
                echo 400000 > /sys/module/i2c_bcm2708/parameters/baudrate
                echo bcm2708_i2c.0 > /sys/bus/platform/drivers/bcm2708_i2c/bind
        fi
        # 1 wire
        modprobe w1-gpio pullup=1
        modprobe w1-therm
        cd /media/
        # Return
        #   0 if daemon has been started
        #   1 if daemon was already running
        #   2 if daemon could not be started
        start-stop-daemon --start --quiet --pidfile $PIDFILE --exec $DAEMON --test --chdir $WORKDIR > /dev/null || return 1
        start-stop-daemon --start --background --make-pidfile --pidfile $PIDFILE --chdir $WORKDIR --startas /bin/bash  -- -c "exec $DAEMON -d $CONFIGFILE >$LOGFILE 2>&1 " || return 2
        # pin codesys to first cpu!
        /usr/bin/taskset -a -p 01 $(cat $PIDFILE);
        sleep 1 && pgrep codesyscontrol > /dev/null && echo "codesyscontrol started" || echo "ERROR: codesyscontrol not started!";
PostPosted: Thu Oct 26, 2017 3:32 pm
which readonly system do you use?
a nice approach would be this one (based on strech lite):
https://www.raspberrypi.org/blog/adafruits-read-only/
PostPosted: Fri Oct 27, 2017 6:13 am
Hello Mr. Schwellinger,
I used the raspian strecht lite (https://downloads.raspberrypi.org/raspbian_lite_latest).
After first boot, i used fdisk to resize root partition to 4gig. Then i created a 3rd partition with the remaining memory (i use a 8gig SD) and folled every step mentioned by your previous post...
Can you explain the first error of my last screen: "cannot find configuration /etc/CODESYSControl.cfg"? Why CODESYS still searching in this directory instead of /media/CODESYSControl.cfg?
Regards,
adv
PostPosted: Fri Oct 27, 2017 8:54 pm
I'm using it that way(this is a bit tricky, guess there are many better solutions for doing it):
Install Stretch lite on the SD Card.
Execute
read-only-fs.sh
I use this jumper on GPIO Pins to select on bootup if the whole SD is monted readonly or not.
- set to rw - insall the CODESYS Runtime via Update Tool
-license the CODESYS Pi runtime
then execute the following script once:
read-only-CDS_after_licenseing.sh
#!/bin/bash
# Use this script to setup the licenses once in RW mode after activateing the license
mkdir /home/pi/cmact_licenses
cp /var/opt/codesys/cmact_licenses/* /tmp/cmact_licenses/
cp /var/opt/codesys/cmact_licenses/* /home/pi/cmact_licenses/
rm /var/opt/codesys/cmact_licenses/*
rmdir /var/opt/codesys/cmact_licenses
sudo ln -sf /tmp/cmact_licenses/ /var/opt/codesys/cmact_licenses
Then add to /etc/init.d/codesyscontrol just before the runtim start
[b]read-only-CDS.sh
[/b]
#!/bin/bash
# CDS Extension make it work this need to be called before CDS runtime starts
mkdir /tmp/cmact_licenses
cp /home/pi/cmact_licenses/* /tmp/cmact_licenses
This procedure copy the license to rw ram - which is needed to have it up an working.
Sure you could only copy new applications to the readonly Pi if you set this Jumper on the GPIO's to have it in RW mode.
PostPosted: Tue Nov 07, 2017 8:31 am
Ok... but that's just another solution for read only raspy and don't solve my specific problem.
Can you just explain, why CODESYS searching in /etc/CODESYSControl.cfg although i modified the /etc/init.d/codesyscontrol...
I think this is the problem, which has to be fixed, instead of changing the whole setup like you described in your previous post...
Regards.
PostPosted: Wed Nov 08, 2017 6:55 am
guess you haved missed to change it here:
PostPosted: Wed Nov 08, 2017 8:01 am
no!
PostPosted: Wed Nov 08, 2017 12:46 pm
Dont understand the messages (see screenshot):
PostPosted: Wed Nov 08, 2017 11:20 pm
you need to move the 3S.dat from /etc/ to your new runtime directory... (Location where CODESYSControl.cfg is located)
PostPosted: Thu Nov 09, 2017 10:23 am
no, already done! :(
EDIT:
Which files are mandatory for licensing?
In which directory has these files to be exist?
Which files/directory has to be writable?
If i go to PLC-settings (SPS-Einstellungen) to "edit license" I see the license (see screenshot):
PostPosted: Thu Nov 09, 2017 10:33 am
hi,
then you Need to adapt this entry here:
