You need to add the Symbol Configuration inside your project and check the OPC UA
You also need to add some text in files, but I have attached some screen dump that I hope can help you further on.
edgarS hat geschrieben:
Hi
I'm new to CODESYS and was wondering if its possible (and how) to define OPC UA methods on the server?
I'm using the CODESYS Control for Raspberry Pi v.3.5.9.10.
Thanks!
there is an entry in our bugtracking/improvement database at the moment I see no release date when this will be in.
Hi Edwin,
is there any update on whether methods may be exposed through the codesys opcua server yet? I have a multinational client and want to put this in front of them as part of our proof of concept demo.
Cormac
Hi
Thanks!
Hello Edgars
It looks like provided procedure is only targeted to exporting variables. What about OPCUA methods (i.e. actions exposed by OPCUA server)?
Thanks!
Hi Edwin,
Cormac
Hi Cormac,
still open and I do not see any implementation/release date for this issue.
Thanks Edwin,
is there anyone I could talk to /ring, about this?
Best regards,
Cormac
Which OPCUA client are you using?
Hi Edwin,
for test purposes Im using Unified Automation uaexpert V1.44 (on windows)
thanks
Hi Edwin,
Some time has elapsed since Cormac asked this question, so I post it again; do you know when methods may be exposed through the codesys opcua server ?
Torgeir
