Does anybody know if there is some Codesys OOP variant of the WITH statement?
This type of statement would be usefull when initiliasing objects or setting more then one property at the same time.
pseudocode example;
WITH <object> DO
.<property1> := Value1;
.<property2> := Value2;
.<property3> := Value3;
.<property4> := Value4;
END_WITH;
Hermsen hat geschrieben:
pseudocode example;
WITH <object> DO
END_WITH;
pseudocode example;
WITH <object> DO
</property4></property3></property2></property1></object>.<property1> := Value1;
END_WITH;
Originally created by: Viacheslav Mezentsev
Originally created by: rickj
You could also use the REFERENCE data type instead of POINTER
The above options will do the trick I guess! thank you for the response!
