This topic was so helpfull for me about getting data from usb via codesys.
I used, Edwin's example it works well. I can read data from my usb GPS receiver.
But, i wonder what if i have 2 usb device at the same time.
How we can control both of them at the same time ? It is possible to do it?
For example;
For one usb device we can use
FirstSerialLine(
slMode:= SL_READWRITE,
udiPort:= 1,
udiBaudrate:= 4800,
paParity:= COM.PARITY.NONE,
sbStopBits:= COM.STOPBIT.ONESTOPBIT,
udiByteSize := ;
what we need to do for 2 usb device at the same time.
Thank you for your help.
ekmekci hat geschrieben:
Dear All,
For example;
FirstSerialLine(
udiPort:= 1,
udiBaudrate:= 4800,
udiByteSize := ;
if 2 usb are the same manufacture, you can change udiport:=2 for second device. You can create news string i/o for the second device.
Lucky!
Hector.
HTejada hat geschrieben:
Lucky!
Hector.
Thank you for your help. But what if i use 2 usb devices which different manufacture ?
What i need to do.
Also, what is the mean "same manufacture" ? Could you please give example ?
set symbolic links in Linux
Example:
/dev/ttyUSB0 -> /dev/USBCDS0
/dev/ttyAMA0 -> /dev/USBCDS1
and then in /etc/CODESYSControl.cfg only this line will be needed: [SysCom]
Linux.Devicefile=/dev/USBCDS
Thank you Edwin,
I will try and i will let you know,
Example:
Dear Edwin,
I did what you said.
Everything works perfect now.
But i have one question about serial com structure.
For example, i have GPS receiver. When i power up the receiver, gps datas comes regularly every one second.
I wonder, it is possible to understand there is data which coming or not.
I mean, according to your example we alwasys try to reading comport every 250ms randomly. If there is data we can get the data if there isnot data we still read comport every 250ms.
Is there any indicator which tell us data is coming or data has come.
I hope i explained well.
Changes in Raspberry Pi 3 related to using the on-board UART:
On PI3, ttyAMA0 is now connected to Bluetooth.
In latest Jessie version /dev/serial0 is the on-board UART (serial).
So, in /etc/codesys.cfg, you must add the line
Linux.Devicefile = /dev/serial
Also, it seems that sometimes the UART is disabled in Kernel.
To enable it, edit /boot/config.txt and set enable_uart=1
Finally, remember to disable the Linux console mode (the serial port is default used by Linux console)
I would like to connect the internal UART from my Raspberry over a MAX485 RS-485 Module from eb.. to an arduino so that i can send data over modbus rtu.
I have done the change in the CODESYSControl.cfg
Now i have the problem that i dont know how to connect the module to the raspberry
I tried it like on this page. LINK
Without success
I have a Modbus COM PORT in my Projekt with a green symbol.
The modbus Master is also green.
But the Modbus Slave is changing between red and orange
Maybe someone can help
Chris
Anonymous
2018-02-02
Originally created by: dosnova
We are trying to connect a serial device via FTDI to Serial USB cable. Communication works fine with minicom but, after following all the steps to link the serial port to Codesys, nothing happens. An Error 5004 (unknown error) is showed. We are trying with the sample project SerialcomwithVisu provided in the Codesys store.
The serial port is identified as "ttyUSB0" and I've added the following lines to CODESYSControl.cfg:
I want to connect two USB slave devices for MODBUS,
The first is a speed variator with a USB / RS485 converter
usb 1-1.5: ch341-uart converter now atachmend to tty USB0
Is Ok.
The second one would be an ARDUINO ONE
cdm-acm 1-1.3: 1.0: ttyACM0: USB ACM device.
Is a ttyUSB1 possible?
Thank you
Fernando
please I need help
I want to control via Raspi (USB to Serial) a Relais Modul. It already worked at my computer (WIN7) and on the Raspi using the console. But using CodeSys I get no acces to the relais. Attached i have summarized the details.
Hoping for Feedback!
Since I'm new to Linux and Codesys, I was hoping that somebody here could help me
I'm using an Apalis Module, with Angstrom version of Linux, and I'm trying to use its serial port with codesys.
The Apalis Module has 4 uart ports(/dev/ttymxc0, 1 ,3 and 4) and I've tested all of them by short-circuiting Rx and Tx Pins and sending an echo command or with minicom. All those tests came out ok. But when I try to use it with Codesys, it doesn't work
I am using this code to open the serial port.
Basically it is the Serial Com example with SysCom Library, the only change was the serial port 4 selected and it is only the code to open it:
VAR
  bOpenCom: BOOL :=TRUE;
  hCom: RTS_IEC_HANDLE :=RTS_INVALID_HANDLE;
  Result: RTS_IEC_RESULT;
  csComSettings: COM_Settings;
  bWriteCom: BOOL :=TRUE;
  dwWritten: UDINT;
  dwOffset: UDINT;
  str : STRING :='abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ1234567890$R$N';
  abyWriteData: array[0..4095] ofBYTE;
  i: INT;
  bReadCom: BOOL :=TRUE;
  dwRead: UDINT;
  strRead: STRING;
  dwWrittenLog : ARRAY[0..49] OFDWORD;
  dwZeroWrittenCount : DWORD;
  iCurWrittenLog : INT;END_VARIFbOpenComTHEN
  bOpenCom :=FALSE;
  //Preparetestdata
  FORi:=0TO4095DO
    abyWriteData[i] :=str[iMOD64];
  END_FOR
  //OpenCOMport4
  hCom :=SysComOpen(sPort:=SYS_COMPORT4 , pResult:=ADR(Result));
  IFhCom<>RTS_INVALID_HANDLETHEN
    //Configuretheconnection
    csComSettings.byParity :=SYS_NOPARITY;
    csComSettings.byStopBits :=SYS_ONESTOPBIT;
    csComSettings.sPort :=SYS_COMPORT4;
    csComSettings.ulBaudrate :=SYS_BR_9600;
    csComSettings.ulBufferSize :=0;
    csComSettings.ulTimeout :=10;
    Result :=SysComSetSettings(hCom:=hCom, pSettings:=ADR(csComSettings) , _:=0);
  END_IFEND_IF
and here is the CODESYSControl text:
Is there any other configuration that I should do? like in the device description of the apalis module?
I hope there is enough information and that somebody knows what is the issue
now i tried removing the number from "/dev/ttymxc", and i don't get the "unknown error" anymore. it returns me a number like 0x12,0x13,0x14,... (i think it's related to some other serial port)
and any of the /dev/ttymxc0, /dev/ttymxc1, /dev/ttymxc3 or /dev/ttymxc4 seems to be opened
edit 2 (solution):
since i was able to open the serial port using these configurations
[SysCom]
Linux.Devicefile=/dev/ttymxc
I figured out what the problem was
apalis uses 4 serial ports, but its names have a gap between uart 2 and uart 3, so should the COM port number be called with this gap
uart1 -> /dev/ttymxc0 -> COM1
uart2 -> /dev/ttymxc1 -> COM2
uart3 -> /dev/ttymxc3 -> COM4
uart4 -> /dev/ttymxc4 -> COM5
so... i was opening 1 port, but instead, was testing another
I am trying to read the data from a GPS Neo Modul into Codesys.
The Modul is connected to the internal pins GND, 3,3V, RS and TX of a Rasperry 3B.
RX and TX are crossed, that means the RX pin of the GPS modul is connected to the TX pin of the Raspi and the TX pin of the GPS is connected to the RX pin of the Raspi.
I have added /etc/CODESYSControl_User.cfg [SysCom]
Linux.Devicefile=/dev/ttyAMA
portnum := COM.SysCom.SYS_COMPORT1;
In /etc/CODESYSControl.cfg I have tried before and deleted the lines now.
In /boot/cmdline.txt I deleted the section "console=ttyAMA0,115200" and the section "kgdboc=ttyAMA0,115000".
If I paste cat /dev/ttyAMA0 | od tx1 in the console I get 0000000 but nothing else.
I installed sudo apt-get install gpsd gpsd-clients.
I restarted the serial port with stty -F /dev/ttyAMA0 9600.
I started GPSD by sudo gpsd /dev/ttyAMA0 -F /var/run/gpsd.sock.
Then I started the gps monitor with cgps -s.
But I don't get anything.
Can somebody help?
Cheers,
Xaver
Yes, serial port is enabled.
I read something about that Bluetooth is connected on the serial pins of the Raspi 3B and that I would have to use an USB to Serial converter to connect the GPS to this type of Raspi.
Can this be?
Cheers,
Xaver
I have established a connection now by using
Linux.Devicefile=/dev/serial
insead of
Now I receive messages in Codesys by using serialComWithVisu example. But the messages don't synchonize. I get a continuous stream of strings from the Serial_Line (FB).
Is there any existing filter or a tool to get the Serial_Line (FB) to synchronize after having received a line feed for example?
Cheers,
Xaver
I just spent the day installing two identical serial devices. One was a RS-485 dongle and the other an RS-485 to TTL adapter for a power supply. Both come up as an "QinHeng Electronics HL-340 USB-Serial adapter" with identical ID's according to "lsusb". The root problem was that occasionally, they would end up swapped. Since they are both identical, there was no distiguishing characteristics for my "udev" rules for the devices. Between this thread and some Linux sites I found a work around. I wanted to share it here in case it may help others, and also so that I can refer back to it after I forget how I made it work
In essence, instead of giving the device a permanent linux device, I gave a permanent linux device to the USB port. It seems each port on the Pi board has a unigue ID. This is shown below as port 1.2-1.5 at the following link:
With this configuration the USB port number (as shown in the link), USB 1.5 will always be Codesys port 1. Likewise USB port 1.3 will always be Codesys port 2, etc. With the tests Ive performed, the comm adapter addresses are now tied to a USB "port" (or slot) rather than being first come first served. With all said and done the Modbus server connected to my dongle is now at (and as long as I dont change slots will be) com device 1. Likewise the Modbus at the other adaptor is and should remain comm 2. Long story short, I know what com port it is based on which slot the device is plugged into.
A word of caution, I dont know how this will act with a USB hub or device besides a com device. My thought is if it causes problems, delete the lines from usb-serial-rules that are not needed. Also, the devices seem to no longer be "hot swappable". From what I have seen a reboot is required if a device is removed and reinserted. Hope this helps someone else also.
With my last ("burnt") raspberry pi and before the reinstallation of codesys, the serial connections were functioning perfectly with many devises as well. Now with the new rapbewrry pi and the new version of the codesys software it is not possible to communicate with a Schneider ATV-12, data doesn`t get to the device, that way it is confirmed that there is no connection. Am I missing any library or were may be the error?
Thanks for the help.
Dear All,
For example;
FirstSerialLine(
udiPort:= 1,
udiBaudrate:= 4800,
udiByteSize := ;
Lucky!
Hector.
What i need to do.
Example:
[SysCom]
Thank you Edwin,
Dear Edwin,
Hi
[SysCom]
Without success
Chris
[SysCom]
Linux.Devicefile=/dev/ttyUSB
Speed, parity, and all the serial parameters have been introduced correctly.
Raspberry version is 3.5.12.0, working with Cedesys 3.5 SP12 x64
We apprecciate your suggestions.
Check if the entry is maybe dublicated or different in CODESYSControl.cfg and CODESYSControl_User.cfg
In the /etc
Thanks Edwin, I've removed the entry from CODESYSControl.cfg and added it to CODESYSControl_User.cfg and now its working fine.
Hi:
Is Ok.
Thank you
Fernando
you need to google for "udev rules" or
"serial-symlinks.rules"
for CODESYS you need a configuration like:
ch341-uart converter is attachmend to ttyUSB0
and your USBAMA0 should then attached to ttyUSB1
Hi All,
please I need help
Indi
HELP.pdf [117.89 KiB]
please move your added SYScom section: [SysCom]
from /etc/CODESYSControl.cfg to /etc/CODESYSControl_User.cfg
means remove it from /etc/CODESYSControl.cfg and Change the existing in /etc/CODESYSControl_User.cfg to
[SysCom]
Linux.Devicefile=/dev/ttyACM
Thanks a lot. Now it works.
Hello All!
Thanks for your time and have a nice day!
edit:
I found out that i was missing a ; in
[SysCom]
Linux.Devicefile=/dev/ttymxc4
portnum := COM.SysCom.SYS_COMPORT4;
but it still doesn't work.
edit 2 (solution):
[SysCom]
CODESYSControl.pdf [228.23 KiB]
Hi to all,
[SysCom]
Can somebody help?
Cheers,
Xaver
Hi Xaver,
maybe a stupid question.
Did you enable this serial port in raspi-config
Hi Edwin,
Can this be?
Cheers,
Xaver
insead of
Cheers,
Xaver
https://askubuntu.com/questions/49910/h ... ters#50412
Armed with this knowledge I then created and edited /etc/udev/rules.d/99-usb-serial.rules. This file contains the following:
SUBSYSTEM=="tty", ATTRS{devpath}=="1.5", SYMLINK+="ttyUSC0"SUBSYSTEM=="tty", ATTRS{devpath}=="1.3", SYMLINK+="ttyUSC1"SUBSYSTEM=="tty", ATTRS{devpath}=="1.4", SYMLINK+="ttyUSC2"SUBSYSTEM=="tty", ATTRS{devpath}=="1.2", SYMLINK+="ttyUSC3"
The 1.5 device is my RS-485 dongle and the 1.3 device goes to the USB-TTL board.
Next I edited /etc/CODESYS_User.cfg. The following lines were added:
[SysCom]Linux.Devicefile=/dev/ttyUSCportnum := COM.SysCom.SYSCOMPORT1;
everything in the same version ( mean CODESYS / CODESYS Runtime?)
except the PI and Stretch whatever you use on this?
SOLVED
Hi Edwin:
CodeSys V3.5 SP14 Patch 2
Runtime V3.5 .14.20
Raspberry Pi 3B
Raspbian Buster 4.19
Fernando
