It is currently Fri Feb 21, 2020 9:53 am
PostPosted: Wed Mar 15, 2017 5:43 pm
I made sample project, installed FESTO FHPP library
https://www.festo.com/net/en-ca_ca/Supp ... _5_5_1.zip
, add devices (from eds files provided by Festo) to Device Repository.
https://www.festo.com/net/en-ca_ca/Supp ... -AS-M3.zip
Now it is time to add drives into project.
Right click on Device in project tree => Add Device => Ethernet/IP > Ethernet Adapter > Ethernet
Now, with right click on the Ethernet I should be able to Add Device which is my Festo drive. I don't see any Festo drives in the list, I search them, no luck. They are still visible in Device Repository.
If I do something wrong, is any tutorial available with description how to add servo drive(s) into project?
Thanks
PostPosted: Thu Mar 30, 2017 5:19 pm
As an update, finally I have got it running. Can confirm that FESTO CMMP-AS servo drive can be controlled on Beaglebone platform via Ethernet/IP.
PostPosted: Mon Nov 19, 2018 6:09 pm
I have a project very similar to this using machine learning, vision, MQTT and RPi3. Boldive could you perhaps offer advice for me?
