maximum modbus tcp slave device
galexis
2017-01-07
2018-11-20
  • galexis - 2017-01-07
    how many modbus tcp slave device, one master can be request ? I can add more than 32 slave under master ....
    Thanks.
  • galexis - 2017-01-18
    One tcp modbus master can have 32 slaves. Does it work well, if I add other tcp modbus master and 32 other slaves ?
  • Kampfwurst - 2017-01-31
    I tried it with about 80 slaves. no problem.
  • galexis - 2017-01-31
    Good !
    Thanks.
  • Anonymous - 2017-02-09
    Originally created by: ph0010421
    To get 80 slaves, did you add 3 Modbus TCP Masters?
    Can I ask how much data you read from each slave?
    thanks
  • CPCS - 2018-11-20
    One Master can have 32 Slaves. After that, you will not be able to add another slave. You can add maximum of 10 Modbus Master. So you can have maximum of 320 slaves for one Application. I tried it with nearly 300 and it worked.
