It is currently Mon Jan 20, 2020 1:54 am
PostPosted: Tue Dec 13, 2016 5:43 pm
Hello together,
I try to connect a Beaglebone Black with CANBus. So i build a Beaglebone Cape for CANBus (you see it in picture):
After that, i followed the instruction of this link: http://www.thomas-wedemeyer.de/beaglebo ... ython.html until the CAN test part (because it doesnt work for me).
And now the Problem: If i try to test the bus with "./cansend can0" nothing happens. So i have measure P9 Pin24 (UART1 TXD) againgst ground and the level still stay at 3,1 V (P.S. i measure with a PicoScope).
Now the question is: what did i do wrong ? Or can there be an other mistake ?
Thanks in advance.
Regards
Hummek
PostPosted: Tue Dec 13, 2016 7:14 pm
using other can capes you need to enable them by:
'For using a CAN cape add following line to /boot/uEnv.txt:
cape_enable=bone_capemgr.enable_partno=BB-CAN1'
Maybe this helps or at least you know what to 'google' for.
PostPosted: Thu Jul 04, 2019 10:24 am
Just if others find their way here.
I used the same link https://www.thomas-wedemeyer.de/beaglebone-canbus-python.html
Followed it all the way through for auto start etc and it works fine.
for candump you may need to install can-utils ........
sudo apt-get install can-utils
then cd /usr/bin
then you can just run
candump can1
NOTE it is can1 NOT can0 !!!!
In codesys make sure to set the Canbus Network to 1 (Not 0) and the correct baudrate
Then add Canopen Manager and then a device.
And if the device is sending PDO's you'll be able to monitor this immediately.
Hope this helps
