It is currently Sun Oct 20, 2019 5:04 am
PostPosted: Tue Nov 22, 2016 9:19 am
i recently started working with the Test Manager to do some automatic Lib Test´s. I would like to aks if there is a possibilty to automaticly export the Results after the Test is finished? If their is a way to export the results could you give me some Tips.
Thanks in advance
Sebastian
PostPosted: Tue Nov 22, 2016 10:50 am
Hi Sebastian.
If you start the test script through the command line you can use the command line parameters "--save-xml=" and/or "--save-html=" to save the test report in its XML format and/or the HTML format. If you want to override existing files you can add "--overwrite-files" to the parameters.
See the chapter "Command line parameters" in the online help for the Test Manager to get the correct syntax because the parameters must be wrapped into "--argX=".
Martin
PostPosted: Mon Nov 28, 2016 2:56 pm
Thanks a lot.
PostPosted: Tue Nov 29, 2016 9:51 am
Hi again,
First i have one question, is it possible to start the Test Manager with a batch File if it is included in the Automation Builder from ABB?
I tried to start it with a Batch File like this:
AutomationBuilder.exe --Profile="Automation Builder 2.0" --executecommand="TestManager ExecuteScript" --arg1:"--repository-location=C:\AutomationTestStructure_V3\CODESYS Test Manager\Test Repository\TestScripts\LibTest" --arg2:"--script=TestProjects" --arg3:"--store"
With this i get only the Massage "´AutomationBuilder.exe´is not recognize as an internal or external command, operable program or batch file"
And i also tried it like this
Start "" "C:\Program Files\ABB\AutomationBuilder\Common\AutomationBuilder.exe" --executecommand="TestManager ExecuteScript" --arg1:"--repository-location=C:\AutomationTestStructure_V3\CODESYS Test Manager\Test Repository\TestScripts\LibTest" --arg2:"--script=TestProjects" --arg3:"--store"
but this only opens the Automation Builder and doesen´t do anything else.
Can you please help me or give some advice?
Sebastian
PostPosted: Tue Nov 29, 2016 4:16 pm
Hi Sebastian.
If you don't execute your command in the directory "C:\Program Files\ABB\AutomationBuilder\Common" the CMD will not find the program "AutomationBuilder.exe" if the directory is not in the environment variable PATH.
The argument for the repository location contains the wrong path. It has to contain only the root directory of the repository. I think in your case it should be "C:\AutomationTestStructure_V3\CODESYS Test Manager\Test Repository". If your test script is not at the top level you have to specify the full name of the test script, for example "MainCategory.SubCategory.Test1". If you select the script element in the test script editor you find the full name in the field "Name". See screenshot.
The argument for the tester is missing. You have to specify the tester with "--tester=xyz".
If there is more than one version of the test script and you want to execute a version, which is not the newest, then you have to add the argument for the version.
Martin
