override init value for VAR_GLOBAL CONSTANT in library from project.
Anonymous
2016-08-05
2020-04-13
  • Anonymous - 2016-08-05
    Originally created by: KevinR
    Dear community,
    i'm using VAR_GLOBAL CONSTANTS in an Library to define upper and lowerbound of an array. All VAR_GLOBAL CONSTANTS, have an predefined init value.
    Now i want to predefine the init value from my Project, where i'm using the Library. I tried to override the VAR_GLOBAL CONSTANTS in the Library from the project, but it doesn't work.
    Is there any solution or work arround?
    Thank you in advance!
  • rickj - 2016-08-05
    You may find this thread of some use
    l viewtopic.php?f=11&t=6971 l
    For libraries, add a library "Parameter list" object (screenshot below). This will allow you to define a constant that can be changed when the library is used in a project. The online help should give more information - topic parameter list and then sub-subject GVL.
    IMG: lib
  • Anonymous - 2016-08-06
    Hello scott,
    thank you for the fast reply.
    I added an Parameter list "Param_XY" in the library:
    VAR_GLOBAL CONSTANT
       // Array Param
       gc_UpBound : INT := 10;
       gc_Length     : INT := 100;
       // Timeout Param
       gc_TimeOut    :TIME := T#10S;
    END_VAR
    FB in Library with Array
    VAR_INPUT
       arrTest : ARRAY [0..gc_UpBound] OF STRING(gc_Length);
    END_VAR
    PRG in Project:
    VAR
       arrXXX: ARRAY [0..gc_UpBound] OF STRING(gc_Length);
    END_VAR
    In the PRG i fill the arrXXX (within the range) and then i call the FB in the library and use the declared arrXXX as Input. This works all fine.
    But I can't change the CONSTANT Vars in the Paramter List "Param_XY".
    I tried to add an GVL in the Project:
    VAR_GLOBAL CONSTANT
       // Array Param
       {attribute 'const_replaced'}
       gc_UpBound : INT := 20;
       gc_Length     : INT := 200;
       // Timeout Param
       gc_TimeOut    :TIME := T#50S;
    END_VAR
    but it doesnt override the paramters in the library and it allways use the parameters from the lib.
    I can't find anything in the help file about that topic expect the attribute 'const_replaced'.
    What I'm doing wrong?
    Thank you in advance.
  • Anonymous - 2016-08-07
    Everything was good until your last step. Don't define the variable again in your main project. Instead, from your project, open the library object (like you are going to add a library to your project) and then highlight your library and look at the available objects - you will see you "parameters" and you can insert the value you want.
  • Anonymous - 2016-08-08
    Scott - thank you so much for your support!
    This was exactly the right thing what I was looking for.
    Have a nice day!
    cheers
  • ssl - 2020-01-03
    scott_cunningham hat geschrieben:
    Hi guys,
    I'm doing a library where i need to be able to change the library constants from the project where the library is used. I simply can not find anywhere where it is possible to add this "Parameter list". Also I find no reference in the help to such a parameter list? Any surgestions on how to achieve changing library constants from project (In 2.3 you simply declared a variable with the same name in the project)
    It seems that "Parameter list" is removed in 3.5.15.x as well as support for libraries pre. version 3 (2.3 libraries)
  • hrimicha - 2020-04-12
    It is maybe a late answer but I faced the same issue and I found the location of the library parameter list as indicated in the photo
  • JAPIB
    JAPIB - 2020-04-13
    Hello, I'm trying to do the same thing and I don't understand how to do.
    Into CODESYS HELP they spoke about ParameterList here :
    https://help.codesys.com/webapp/_cds_cmd_save_project_as;product=codesys;version=3.5.15.0 , in the chapter "Before saving a project as a library:"
    "A parameter list is a special type of global variable list." yes, but how to get it ?
