PLC configuration how to see used IO
FabioPD
2016-07-06
2016-07-14
  • FabioPD - 2016-07-06
    Hi I need to know what IO in PLC configuration are effectvely used by a tag or variable in the project. How to do this with codesys V 2.3.9 ? If the programmer hasn't assigned variable name to the IO I imagine there isn't a way to know the total used and free IO channels of a device in IO bus....
  • shooter - 2016-07-10
    under resources you can find the configuration, here should be a list of used i/o
    you can also export this
    check the global vars as i/o are always global.
    if they are in the POU declared, you will have to make a list yourself.
    if you export the program and all POU you can easy search them with an external editor.
    internal also ctrl F with simple %I and %Q
  • FabioPD - 2016-07-11
    shooter hat geschrieben:
    Ok thank you very much !!
    And how to know the code/ram memory usage ?
  • shooter - 2016-07-14
    when compiling you will see memory usage in the report
