Hi I need to know what IO in PLC configuration are effectvely used by a tag or variable in the project. How to do this with codesys V 2.3.9 ? If the programmer hasn't assigned variable name to the IO I imagine there isn't a way to know the total used and free IO channels of a device in IO bus....
under resources you can find the configuration, here should be a list of used i/o
you can also export this
check the global vars as i/o are always global.
if they are in the POU declared, you will have to make a list yourself.
if you export the program and all POU you can easy search them with an external editor.
internal also ctrl F with simple %I and %Q
shooter hat geschrieben:
Ok thank you very much !!
And how to know the code/ram memory usage ?
when compiling you will see memory usage in the report
