It is currently Tue Dec 11, 2018 8:59 pm
 Post subject: SoftPLC to OPC Server
PostPosted: Wed Oct 07, 2015 11:41 pm
Hello, first post here
I'm exploring the option of using Codesys as a SoftPLC to test PLC programs on my laptop. I want to install an OPC server on the network that will be used to test applications using OPC data.
Is it possible for the SoftPLC to communicate with a remote OPC server? If so, which OPC servers are compatible?
Also, I'm not sure exactly what functionality the SoftPLC has therefore I'm not sure it is suitable for what I am looking for. Can it / Does it act as a simulator? I don't have any physical IO i want to connect to I just want to simulate IO in the PLC program.
Thanks in advance
PostPosted: Fri Oct 16, 2015 4:11 am
I would recommend use CODESYS V3 - Control Win plc.
This is the softplc without realtime capabilities and an built in OPCUA Server is included.
No externel OPC Server is needed.
Optional you could add IO's by an Ethernet based fieldbus (Ethercat/Profinet/EthernetIP.....etc)
How to start?
Download CODESYS V3
http://store.codesys.com/engineering/codesys.html
-After installing and executing the CODESYS developmentsystem to our pc you need to start the plc
-use attached example project, start the plc, scan it by CODESYS and download the project and start it
- connect you OPCUA Client to the plc and browse the symbols
This is a lot easier than using an external OPC Server which offten is hard to configure.
PostPosted: Fri Oct 23, 2015 10:29 pm
Hi Edwin thanks for your response.
I appreciate the difficulties in configuring an external OPC server but in reality I would find it useful to get the practical experience of solving these issues. Is an external OPC server compatible with the Control Win?
Also, what is the difference between Control Win and Control RTE? I understand RTE is real time but how can a PLC not be real time?
PostPosted: Fri Oct 30, 2015 5:13 pm
yes the OPC Server is compatible with Control Win and Control RTE.
Some Application do not really have this requirement..
