It is currently Fri Jan 17, 2020 2:48 pm
 Post subject: New version?
PostPosted: Wed Jan 21, 2015 11:49 am
I have been running on the original CoDeSys image.
I periodically would do a
sudo rpi-update
updating to the latest kernel.
This morning the kernel was at 3.12.36+ and everything was working fine before I did the update.
After the update, the kernel is at 3.18.3+
Now the codesyscontrol task is not running. So the update broke something.
I know a new version of CoDeSys is supposed to be near release, so the question is...
How soon?
Thanks,
Dennis
PostPosted: Wed Jan 21, 2015 12:14 pm
Hi Dennis,
thanks for the information,
you are right we will fix this to next version, at the moment it is not recommended to use rpi-update.
 Post subject: Re: New version?
PostPosted: Tue Feb 03, 2015 1:36 pm
Edwin,
I just did...
sudo rpi-update
again. It seems to have picked up some stuff supporting the Pi 2 B.
Upon reboot, the codesyscontrol task is running again.
I then did...
sudo apt-get update
sudo apt-get upgrade
It seems to have picked up a bunch of changes that support the Pi 2 B.
The following NEW packages will be installed:
libpng12-dev libportaudio2
The following packages will be upgraded:
epiphany-browser epiphany-browser-data gnome-accessibility-themes
gnome-themes-standard gnome-themes-standard-data libc-bin libc-dev-bin libc6
libc6-dev libfreetype6 libfreetype6-dev libjavascriptcoregtk-3.0-0
libpixman-1-0 libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc
libraspberrypi0 libwebkitgtk-3.0-0 libwebkitgtk-3.0-common locales
multiarch-support raspberrypi-bootloader raspi-config sonic-pi
wolfram-engine
25 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
IT did not install cleanly...
Err http://archive.raspberrypi.org/debian/ wheezy/main raspi-config all 20150131-1
503 Service Unavailable [IP: 93.93.130.39 80]
Err http://archive.raspberrypi.org/debian/ wheezy/main sonic-pi armhf 2.3.0-1
Fetched 335 MB in 4min 33s (1,226 kB/s)
Failed to fetch http://archive.raspberrypi.org/debian/p ... -1_all.deb 503 Service Unavailable [IP: 93.93.130.39 80]
Failed to fetch http://archive.raspberrypi.org/debian/p ... _armhf.deb 503 Service Unavailable [IP: 93.93.130.39 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Thought you'd like to know.
I really hope the Pi 2 B will be supported by CoDeSys. That would be awesome!
Dennis
PostPosted: Tue Feb 03, 2015 2:00 pm
I reran the update and upgrade commands.
This time it completed cleanly after a long time.
Upon reboot the codesyscontrol task is not running.
Is there an error log that I can look at that will tell me why the task did not start?
Thanks Edwin.
Dennis
PostPosted: Tue Feb 03, 2015 7:13 pm
Hi Dennis,
I'll send you a fixed version.
This issue is solved with the upcoming 3.5SP6 Release.
Users browsing this forum: phenixrb and 7 guests
