Where we can find info's for the parameters that accepted from CODESYSControl.cfg?
Where we can find info's for the parameters of Webserver like port number max client number...?
Regards
the max num of Client you need to setup in CODESYS on the VisualisationManager 'Extended settings'
client settings
Maxiumum number of Visualisation Clients
not really, this is covered by the manual which you get if you use a runtime toolkit which is not free of charge.
Maybe we need to extract the config file part from that documentation if that is possible.
Anonymous
2018-11-19
Originally created by: KevinR
Has this already been done?
Hi again.
Regards
in /etc/CODESYSControl.cfg
[CmpWebServer]
WebServerPortNr=8080
client settings
Is there any guide for the CodesysControl.cfg?
