CODESYS Modbus TCP Master/Slave - BK9000 - doesn't work
Dude82
2019-08-27
2019-08-27
  • Dude82 - 2019-08-27
    In CODESYS 3.5 V15 I try to read data on Modbus from a Beckhoff Ethernet coupler ( BK9000+KL3314: input for thermocouple + KL3064 : Input 0-10V)
    I have added an Ethernet Generic device and then add Modbus TCP Master and Slave (as I have seen in others threads).
    I think I have put the proper parameters (IP adress: 192.168.1.48 = my BK9000 on the network, port = 502)
    I have added input canal Chanel 1 with Read Holdings register (Offset = 1 (=0x0001) and data = 1) but I can't get any value when the program runs on the PLC (here a Raspberry with Jessie)
    This is very surprising to me , because I can read both the value usine Python (with the pymodbus lib)
    in python 3.7.4 on my windows computer
    from pymodbus.client.sync import ModbusTcpClient
    client = ModbusTcpClient('192.168.1.48', '502')
    rr=client.read_holding_registers(1,1)
    print('input: ', rr.getRegister(0))
    It gives me the proper value of the Thermocouple
    When I use KS2000 from Beckhoff, I can read also the value from Channel 1.
    Do you know what i'm doing wrong in CODESYS ? It makes me made not to understand where the problem is.
    IMG: Data_read_on_KS2000.png
    IMG: Config_Modbus_Slave_device.png
    IMG: Config_Ethernet_device.png
    Solution found.
    Sometimes I feel that I'm not very clever. By the way, I just forgot to enabled an option about the updated of the variable.
    indeed in the configuration of the PLC device (Here a Raspberry): Enable 1 ("Use bus cycle task if not used in any task") must be used in my project.
    I can now get the thermocouple values through MODBUS.
    IMG: problem_soved.jpg
    IMG: option_to_solve_the_problem.jpg
