It is currently Sun Feb 23, 2020 11:23 am
PostPosted: Wed Aug 24, 2016 6:57 am
Hello!
I'm using PLCHandler library.
Having simple IEC project with an array of strings
PROGRAM PLC_PRG
_arr_string : ARRAY[1..10] OF STRING(10) := ['aaa','bbb','ccc','ddd','eee','fff','ggg','hhh','iii','jjj'];
I got the list of variables by calling GetAllItems().
PlcSymbolDesc for this variable contains
'Application.PLC_PRG._arr_string', typeID(131085)-'ARRAY [1..10] OF STRING'-'ARRAY : DATATYPE_STRING', size '110', access 'b', RefId '0', offset '0'
'Application.PLC_PRG._arr_string[10]', typeID(13)-'STRING'-'SIMPLE : DATATYPE_STRING', size '11', access 'b', RefId '0', offset '0'
'Application.PLC_PRG._arr_string[1]', typeID(13)-'STRING'-'SIMPLE : DATATYPE_STRING', size '11', access 'b', RefId '0', offset '0'
'Application.PLC_PRG._arr_string[2]', typeID(13)-'STRING'-'SIMPLE : DATATYPE_STRING', size '11', access 'b', RefId '0', offset '0'
'Application.PLC_PRG._arr_string[3]', typeID(13)-'STRING'-'SIMPLE : DATATYPE_STRING', size '11', access 'b', RefId '0', offset '0'
'Application.PLC_PRG._arr_string[4]', typeID(13)-'STRING'-'SIMPLE : DATATYPE_STRING', size '11', access 'b', RefId '0', offset '0'
'Application.PLC_PRG._arr_string[5]', typeID(13)-'STRING'-'SIMPLE : DATATYPE_STRING', size '11', access 'b', RefId '0', offset '0'
'Application.PLC_PRG._arr_string[6]', typeID(13)-'STRING'-'SIMPLE : DATATYPE_STRING', size '11', access 'b', RefId '0', offset '0'
'Application.PLC_PRG._arr_string[7]', typeID(13)-'STRING'-'SIMPLE : DATATYPE_STRING', size '11', access 'b', RefId '0', offset '0'
'Application.PLC_PRG._arr_string[8]', typeID(13)-'STRING'-'SIMPLE : DATATYPE_STRING', size '11', access 'b', RefId '0', offset '0'
'Application.PLC_PRG._arr_string[9]', typeID(13)-'STRING'-'SIMPLE : DATATYPE_STRING', size '11', access 'b', RefId '0', offset '0'
Reading the data by SyncReadVarsFromPlc() brings me the following (hex trace):
- for single array element 'Application.PLC_PRG._arr_string[1]' - (length 11) - a a a 00 00 00 00 00 00 00 00 hex
- for array 'Application.PLC_PRG._arr_string' - (length 110) - a a a 00 00 00 00 00 00 00 00 b b b 00 00 00 00 00 00 00 00 c c c 00 00 00 00 00 00 00 00 d d d 00 00 00 00 00 00 00 00 e e e 00 00 00 00 00 00 00 00 f f f 00 00 00 00 00 00 00 00 g g g 00 00 00 00 00 00 00 00 h h h 00 00 00 00 00 00 00 00 i i i 00 00 00 00 00 00 00 00 j j j 00 00 00 00 00 00 00 00 hex
The question is - how can I parse the data block (length 110 bytes) which I received for whole array variable _arr_string? There is no info about length of each array element in PlcSymbolDesc for _arr_string.The length of each element can only be seen in PlcSymbolDesc for _arr_string[XXX] - 11 bytes. But symbol descriptions for the array and its elements are only linked by the symbol names - I think it's not the right way to get array element size by comparing the names of PlcSymbolDesc structures. The same with the symbol type name of the variable ('ARRAY [1..10] OF STRING') in the field PlcSymbolDesc.pszType. Is there any other _more_simple_ way to handle this?
BR, Eugene
PostPosted: Fri Jan 27, 2017 8:21 pm
you can always ask the LEN of any string.
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
