SEW Movidrive B control using PLCOpen in Codesys v3.5
dwpessoa
2019-07-22
2019-07-24
  • dwpessoa - 2019-07-22
    Hello!
    I intend to use a Codesys 3.5 CLP and Softmotion to control a SEW Movidrive B driver by CanOpen or EtherCAT.
    I know that the SEW driver does not support CIA DS402... they currently have Movidrive C, which supports, but in this application I have no choice... They also have MoviPLC, which is based on Codesys v2.3 and has the library PLCOpen and allows the control of the Movidrive B, but I can not use this PLC (limitations of the system).
    I can add the ESI / EDS file and read / write PDO without problems, but the option to add the Generic Axis Softmotion does not appear. I know the reason thanks to a post from Edwin Schwellinger (thanks!).
    My questions:
    1. Is possible to implement an interface to the axis manually and use the PLCOpen fbs?
    2. Is there any documentation that explains how to do this?
    3. I would have some limitation (Not being able to use Gear, for example)?
    IMG: Screenshot_2.png
  • eschwellinger
    eschwellinger - 2019-07-24
    could you add the EDS file?
    If this device is DS402 compliant you could try the generc DS402 Softmotion driver.
    These drivers are all set by a paid service - to do this manually for this is not really possilble and recommended - no documentation etc
    I would try to ask SEW if this is possible to use with CODESYS & SoftMotion.
    IMG: AddDS402Generic.png
  • dwpessoa - 2019-07-24
    Hi Edwin,
    Yes, I was able to add the EDS file (attached, FW_17). In the previous post is the MDX device in the tree, and has no option to add the Softmotion Generic Axis.
    In the fieldbus manual there is a definition that the device has no DS402 implemented.
    I believe SEW shouldn't have any intention of developing the interface for DS402 for MoviB because of the new MoviC line. I will try to perform the control in PD and see if the response time meets my application.
    Thank you so much for your time Edwin! \o_
    SEW_EDS CO_MOVIDRIVE B_V1 6.zip [142.89 KiB]
