https://forum.codesys.com/
Manage AX5101 drive and AX5805 safety module
https://forum.codesys.com/viewtopic.php?f=6&t=8645
Page 1 of 1
Author:  MarcoF [ Tue Feb 27, 2018 3:35 pm ]
Post subject:  Manage AX5101 drive and AX5805 safety module
I'm trying to manage a Beckhoff AX5101 drive with the AX5805 safety module and the EL6900 safety PLC from CoDeSys.
Has anyone already built a similar network? Are there any sample projects to download?
When I try to import the ESI Beckhoff ELx9xx.xml file, 2 errors are reported with code #22 concerning the AX5805 module, how can I resolve these errors?
I'm using CoSeSys V3.5 SP11 Patch 4.
Thanks for any suggestions.
Author:  Edwin Schwellinger [ Thu Mar 01, 2018 7:42 am ]
Post subject:  Re: Manage AX5101 drive and AX5805 safety module
could you attach the ESI file which you try, could not find the AX5805.
There will coming up a new release 4.0.3.0 (this month) hope this will solve it.
Author:  MarcoF [ Thu Mar 01, 2018 9:01 am ]
this file has been extracted from the available device folders created by TwinCAT3.
I also tried with a version dated 2013 but the installation ends with the same error # 22.
Marco
Author:  MarcoF [ Fri Mar 09, 2018 8:17 am ]
Hi Edwin,
have you checked the problem I reported?
With the current library there are workarounds that allow me to continue with some preliminary tests of the network and safety functions?
Marco
Author:  Edwin Schwellinger [ Sat Mar 10, 2018 6:23 am ]
Hi Marco,
in current Version this is still a problem yes but (3.5SP12Patch1)
I see that this will be solved with the 3.5SP13 Version(June).
Author:  Edwin Schwellinger [ Mon Mar 12, 2018 8:01 am ]
ups... I did another test with new upcoming safety EL6900 release, and this still does not work.. even with SP13 and
and upcoming 4.0.3.0 EL6900 Release.
Let me check to when this is planned/scheduled to fix.
Author:  MarcoF [ Thu May 17, 2018 3:36 pm ]
Hi Edwin,
are there news about the problem I reported?
Can I follow it in the Codesys bug tracker?
Marco
Author:  Edwin Schwellinger [ Thu May 17, 2018 6:07 pm ]
Hi Marco,
I see 3 points related to that:
CDS-58773
SCDS-1612
SCDS-1310
not sure if this forum is the right place for this..
https://www.phpbb.com/
