It is currently Tue Jul 17, 2018 3:13 am
PostPosted: Mon May 22, 2017 11:05 am
Question
I have an xyz 3axis system .
How do I connect an additional Q-axis to smc_interpolator so it is also controlled bij cnc (g code)?
The xyz you connect to the SMC_interpollator Pisetposition output with Trafo_gantry 3 function blok .
How do I connect/control the additional Q-axis ? ( to smc AxisConytrolByPos in CFC programming ?)
PostPosted: Sat May 27, 2017 8:27 am
check the online help,
depending on what you Need uvw or a,d,c axis..
PostPosted: Tue Jun 06, 2017 12:04 pm
Didn"t find any info in online help about additional axis! (only how to use in g-code, but not how to connect to smc_interpolator ).
Did I miss relevant info/pages in online help?
tried some options and used Q-axis in G-code and found out that you have to use dA2 variable from smc _ Interpolator to connect to smc_ControlAxisByPosition
The axis controled in this way does not finish a task! .
If I use for example Q25 and next step Q0 it will start but not finish the first task, but right away steps to next line .
I can solve it with G4 T.. (time delay )
Do I something wrong here or does it work this way. Did I forget to connect a feedback?
