SDO read and write
leon517
2016-12-22
2021-03-13
  • leon517 - 2016-12-22
    SDORead : ETC_CO_SdoRead;
    SDOWrite : ETC_CO_SdoWrite;
    I want to read&write SDO from ethercat slaves using these FBs.
    When I write to SDO,it always fail,even I changed to write other address,such as 0x6099.Meanwhile reading always good.
    But my friend use the the FBs to write another ehtercat slaves,read and wirte SDO both good.
    My question:
    Is it the slave's problem about write SDO error?
    IMG: SDOw.jpg
    eschwellinger - 2016-12-28
    do you use this example from here:
    After installing this package you'll find the example here:
    "c:\Users\<yourwindowsusername>\CODESYS Examples\EtherCAT Example"
    Edwin</yourwindowsusername>
    IMG: EthercatExample.jpg
  • leon517 - 2017-01-19
    But I do not want to use EtherCAT Example.
    Why the way I used do not work?And what is the problem?
    Tks,anyway!
  • ahdelta - 2017-02-05
    Did you ever find a solution to the ETC_CO_sdoWrite problem?
    I have the same issue. I can read Sdo's fine, but can't write anything.
    I have downloaded and using the Ethercat example from CodeSys Store.
    Have tried to write with ETC_CO_sdoWrite and ETC_CO_sdoWrite4, but no luck.
    With ETC_CO_sdoWrite, I get the error:
    ETC_CO_FIRST_ERROR,
    SdoAbort: 16#06090031, if using WORD, and 16#06070010 with DWORD as write value.
    I can't find any description about the error, or errocode.
    !!! Update:
    It turned out the values I am writing are not within legal range.
    So problem solved.
  • tariq - 2021-03-13
    Hi Leon,
    Do you have an example how to used ETC_CO_sdoRead. I really appreciate your help.
    eschwellinger - 2021-03-13
    Here in Forge, Projects- CODESYS Examples...Ethercat
    Last edit: eschwellinger 2021-03-13
