It is currently Sun Nov 17, 2019 5:34 am
 Post subject: G-Code with M Code
PostPosted: Mon Apr 18, 2016 11:05 am
I have difficulities with combining G-Code and M-code.
For example:
M127
M104 S205 T0 ; set temperature
G1 X0 Y0 Z5 F1000 ; lift nozzle <- the machine immidiately jumps to the set speed without any acceleration (the machine makes a jerk)
G21 ; set units to millimeters
G90 ; use absolute coordinates
The following code works smoothly:
G1 X0 Y0 Z5 F1000 ; lift nozzle <- the code is the same
M127
For some reason, if the G-Code starts with an M-command, the first next G-command causes a jerk on the machine.
If we remove the M-command from the beginning, the code causes no jerks on the machine.
What command should I use with SoftMotion, so we can avoid the problem?
