It is currently Mon Feb 17, 2020 10:44 am
PostPosted: Thu Sep 19, 2019 4:24 am
How to reset the current encoder position of ethercat servo drive to zero?
PostPosted: Sun Sep 22, 2019 7:12 am
Checkout this function block, MC_SetPosition:
https://help.codesys.com/webapp/7d42hfw ... on=4.3.2.0
PostPosted: Wed Sep 25, 2019 2:02 pm
Hey Campbell,
I tried the function out. When I cycle the power of the system the motors' position is unchanged which was earlier set to '0' by using the MC_Setposition FB as suggested. I kindly request you to please help me out with this.
PS is there any FB which retains the position to a set value even after the cycle power is done?
with regards,
Kanishk Navale
PostPosted: Wed Sep 25, 2019 5:27 pm
Hi Kanishk,
Using MC_GroupSetPosition doesn't work because when you power up drive and motor after they're off, Codesys will receive the absolute position from the encoder.
I think you should find the parameters of your drive that can perform a preset position and then using FB which can force the value of the parameters.
hope it will be useful for you
with regards
PostPosted: Wed Sep 25, 2019 7:06 pm
Hi hi Kanishk,
Go to help.codesys.com and search for "Persisting an Axis Position". Check the first result
PostPosted: Sat Oct 26, 2019 11:46 am
I-Campbell wrote:
Hi hi Kanishk,
Hi Campbell,
I have implemented the logic as per the link. In the attached screenshot, the persistent position data is not able to store the 0 values of the axes when I zero them using Set_Position FB but, still, it is storing the initial values of the motors. How to move forward with this?
