Reset encoder position to zero
2019-09-19
2019-10-26
  • navalekanishk - 2019-09-19
    How to reset the current encoder position of ethercat servo drive to zero?
  • navalekanishk - 2019-09-25
    I-Campbell hat geschrieben:
    Checkout this function block, MC_SetPosition:
    https://help.codesys.com/webapp/7d42hfw ... on=4.3.2.0
    Hey Campbell,
    I tried the function out. When I cycle the power of the system the motors' position is unchanged which was earlier set to '0' by using the MC_Setposition FB as suggested. I kindly request you to please help me out with this.
    PS is there any FB which retains the position to a set value even after the cycle power is done?
    with regards,
    Kanishk Navale
  • drsumruay - 2019-09-25
    Hi Kanishk,
    Using MC_GroupSetPosition doesn't work because when you power up drive and motor after they're off, Codesys will receive the absolute position from the encoder.
    I think you should find the parameters of your drive that can perform a preset position and then using FB which can force the value of the parameters.
    hope it will be useful for you
    with regards
  • i-campbell
    i-campbell - 2019-09-25
    Hi hi Kanishk,
    Go to help.codesys.com and search for "Persisting an Axis Position". Check the first result
  • navalekanishk - 2019-10-26
    Hi hi Kanishk,
    Hi Campbell,
    I have implemented the logic as per the link. In the attached screenshot, the persistent position data is not able to store the 0 values of the axes when I zero them using Set_Position FB but, still, it is storing the initial values of the motors. How to move forward with this?
    IMG: Screenshot from 2019
