It is currently Sun Oct 20, 2019 10:08 am
PostPosted: Wed Jan 23, 2019 4:17 pm
I need to visualize into Codesys 2.3 HMI an INT value like this:
myVAR:INT;
100 = 10.0 sec
is there some way to get 10.0 visualization using INT? I found this
but if it's ok on reading, when I write it miss 0.1 : ex I write 10 , then I should expect 100 into INT var but I get 99!
Any help is appreciated
PostPosted: Thu Jan 24, 2019 2:16 am
If I understand you idea, you want to :
dispay 10.0 if MyVar=100
display 10.2 if Myvar=102
and so on ...
To do that you can, in the settings of a rectangle (by example) write :
Category Text -> Content: %2.1f //display format for a REAL, with 2 digits before point and 1 digit after
Category variable -> Textdisplay : INT_TO_REAL(MyVar)/10 //conversion of the INT into REAL, then division by 10
Another solution could be :
Category Text -> Contente: %2.1f //display format for a REAL, with 2 digits before point and 1 digit after
Category variable -> Textdisplay : INT_TO_REAL(MyVar) //conversion of the INT into REAL
Conversion factor : 0.1 //Division by 10
:D
It works ... but you can't change the value of MyVar directly by this rectangle. You can't have a text imput with a such equation. :cry:
If you want to change the value of MyVar, you have to add another rectangle close the display (I put it in the background under the first, letting it go a little beyond, so I can click on it).
In this second rectangle you can display MyVar with %d and configure a text input.
It's just an idea. Maybe there is a smarter solution ?
PostPosted: Thu Jan 24, 2019 5:41 pm
great it works! I 100% miss I can use conversion function into HMI, good to know.
