https://forum.codesys.com/
Library with function block related visu: table problem
https://forum.codesys.com/viewtopic.php?f=5&t=6128
Page 1 of 1
Author:  RudolfAtITD [ Wed Apr 01, 2015 6:07 pm ]
Post subject:  Library with function block related visu: table problem
Hello to the experts!
I'm developing a library with a couple of function blocks, each with an associated visu. All things runs well - with one exception: For a diagnostic function block a table should show the diagnostic data. They are located in an ARRAY [1..200] OF <struct>. An output variable of the function block defines this array:
DiagBuff    : ARRAY [1..200] OF ..._DIAGMESSAGE;
When I insert a table into the related visu, it is not possible, to assign this output variable in the usual form $INST$.DiagBuff. This variable is not shown with F2 and also the table columns are empty. In the CoDeSys Help I found an example with a direct variable connection: PLC_PRG.<Daten>.
Is the indirect variable assignment $INST$<Data> not working with tables? Is there an alternative?
My version: CoDeSys 2.3.9.42 (pbF).
Author:  RudolfAtITD [ Thu Apr 02, 2015 5:27 pm ]
Post subject:  Re: Library with function block related visu: table problem
My working work-around: I place the Array as a Global var. And it seems to work.
Author:  shooter [ Wed Apr 08, 2015 8:21 pm ]
what about the dot you are using.
and in V2.3 n dynamic variable can be made.
https://www.phpbb.com/
