It is currently Tue Mar 19, 2019 8:04 pm
PostPosted: Wed Apr 01, 2015 6:07 pm
Hello to the experts!
I'm developing a library with a couple of function blocks, each with an associated visu. All things runs well - with one exception: For a diagnostic function block a table should show the diagnostic data. They are located in an ARRAY [1..200] OF <struct>. An output variable of the function block defines this array:
DiagBuff    : ARRAY [1..200] OF ..._DIAGMESSAGE;
When I insert a table into the related visu, it is not possible, to assign this output variable in the usual form $INST$.DiagBuff. This variable is not shown with F2 and also the table columns are empty. In the CoDeSys Help I found an example with a direct variable connection: PLC_PRG.<Daten>.
Is the indirect variable assignment $INST$<Data> not working with tables? Is there an alternative?
My version: CoDeSys 2.3.9.42 (pbF).
PostPosted: Thu Apr 02, 2015 5:27 pm
My working work-around: I place the Array as a Global var. And it seems to work.
PostPosted: Wed Apr 08, 2015 8:21 pm
what about the dot you are using.
and in V2.3 n dynamic variable can be made.
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
