It is currently Wed Mar 20, 2019 4:24 pm
 Post subject: Numerical Keypad
PostPosted: Wed May 08, 2013 9:18 pm
I working on a project using the numerical Keypad in CodeSys 3.5 visulation program. I can get the Keypad to appear on the screen, and the value that the variable is already set to is written tokeypad input box. But when I enter a new value and press OK, the value does not get written to the variable I want edit and the keypad does not close. On a mouse down event I am using the Write Variable option and picking the Numerical Keypad as the Edit method. Any thoughts or ideas on the problem would be appreciated.
 Post subject: Re: Numerical Keypad
PostPosted: Mon May 13, 2013 9:10 am
your variable is updated somewhere else, just make a new variable for this input and use it only once as input the rest as output.
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
PostPosted: Thu May 23, 2013 3:34 am
Found the answer. At the beginning of my project I thought I has would need to make my own visualization for a numerical keypad and created a visualization named Numpad. I never used it but did not delete it after I figured out how to use the keypad function built into CodeSys. When I added a mouse down event to write a variable using the Numpad, it did not like that I had a visualization called Numpad. As soon as I deleted the visualization the keypad worked fine.
