Plot an x-y profile (graph) in visualisation.
2010-03-05
2017-08-15
  • DIPTI KUDKE - 2010-03-05
    I have to plot an x-y profile (graph) in visualisation. How can I do it?
  • Igor Petrov - 2010-03-11
    You could prepare an array Y1[X1], Y2[X2]...etc. Next use Histogram with presentation options Curve. You will see the x-y spline curve.
  • cieffe76 - 2010-03-15
    Hello Igor, I'm interested about the x,y profile plot.
    I try to do a curve histogram with an array like
    Y:ARRAY[1..10] OF INT:=1,2,3,5,6,8,1,2,4,8;
    but I see an empty histogram.
    can you explain how it works.
    thanks.
    bye
  • shooter - 2010-03-15
    I would do it with pieces of line and put them in an array.
    much like your histogram but i can make drawings and even openings.
    i made example with array and rectangles. changed them to lines so i have begin and endpoint.
    also possible with line command with scale and direction.
    scale is length of line
  • cieffe76 - 2010-03-17
    hello everybody, I try to do it in this way
    scale start 0
    scale end 10
    mainscale 1
    subscale 1
    unit
    variable Y[1]
    type curve
    arraybegin 1
    arrayend 10
    bandwidth 90
    but in run mode the graph is empty...
    can you help me?
    thanks a lot.
    Bye
    Related
    Talk.ru: 1
  • Igor Petrov - 2010-03-30
    See attached picture and project (V2.3.9):
    PROJECT
    IMG: Bild
  • cieffe76 - 2010-03-30
    Thanks a lot.
    It works. in my example was wrong only the variable.
    I set "variable Y[1]" , the first item of the array and not the array
    "variable Y"...
    I will use it!
    Bye
  • galexis - 2016-10-19
    Have example for codesys 3 ?
    eschwellinger - 2017-08-15
    XY Element will be released with 3.5SP12 (December)
