It is currently Mon Jan 21, 2019 12:23 pm
PostPosted: Mon Jul 11, 2016 8:53 pm
Hi everybody
This is my first post and I was wandering if someone could help me..
I had a codesys v2.3. Application that was running properly but last time I started my application..the runtime sp rte haven't started....
I try ed to run it manually but without result..
Into the runtime property I read
Kernel not loaded
Thread not started.
How can I fix this problem?
Thanks in advice.
PostPosted: Tue Jul 12, 2016 6:30 pm
if the SP RTE has already worked on this pc (without changing the OS or hardware)
I would recommend to delete the Bootproject (DEFAULT.prg and DEFAULT.chk) in the RTE directory.
PostPosted: Mon Jul 18, 2016 10:50 pm
Hi Edwin
thank you very much for your answer ..I'll try to do what you suggest and then I'll let you know ASAP
Thanks again
PostPosted: Sat Jul 23, 2016 3:18 pm
Hi Edwin
I did what you suggest (delete boot project files)
but with no result...
In the RtSysTry system property I still have
The kernel is not loaded
The scheduler is inactive
Do you have any idea on how could I fix this problem please???
Many thanks..
PostPosted: Tue Jul 26, 2016 7:00 am
Hello Rainer,
no other idea, than check together online... - email to support
PostPosted: Wed Jul 27, 2016 7:14 am
Hi Edwin
I have some new information about the problem....
I have a Hilsher pci board in order to communicate with I/o field.. and I found that if I delete the Hilcher driver declaration
in a rte system settings.. everything works correctly...
May be I have an hw problem on this board?
I'll let you know
have a nice day
