It is currently Wed Mar 20, 2019 5:01 pm
PostPosted: Tue Apr 07, 2015 7:21 am
I'd like to ask you a few questions about cosesys simulation. Firstly why when I in the simulation a pulse generator I get a rump to and from 1. Is this the time it takes to reach 1? And why do I get four correct pulses and then after some time I get again four correct pulses? The pulse generator should produse pulses with the same period.
PostPosted: Tue Apr 07, 2015 4:14 pm
the simulator is very slow, as it needs to interpret a machine-code not used in the PC but like an ATMega.
So when using times it will not be precise, however in some cases it even works.
The visualisation of it is also very time consuming.
It is really only good for getting things to work, do not expect a great working thing.
When you download it to a PLC it will be running just fine.
In the simulator it will run a task until it needs to go to display handler keyboard mouse etc.
Try to stop as much processes as you can to speed up the PC.
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
