It is currently Sat Feb 23, 2019 9:43 pm
PostPosted: Fri Oct 21, 2011 2:24 pm
Hi Everybody,
I have noticed a very interesting problem in CodeSys 2.3. Actaully I am using CodeSys SP RTE target PCAN PCI. Everything is ok. As I can get all "StatusWORD" signal from my Canopen Node. But problem is like that:
If I have written a very simple program in ST for "CASE... OF" condition , It works only in Simulation mode but when I load it in RTE SP PLC then it build & runs but it does not change the "CASE..OF" State. Case state has no change, it goes only in State 0: as it is first commnad but not State 1 or further. But in simulation , it works fine in all State.
calltimer;
inputtime:=calltimer.timeroutput;
CASE state OF
0: output:=4;
IF inputtime=t#5s THEN state:=State+1; END_IF;
1: output:=5;
IF inputtime=t#10s THEN state:=State+1;END_IF;
2: output:=90;
IF inputtime=t#15s THEN state:=3;END_IF;
3: output:=80;
IF inputtime=t#20s THEN state:=state+1;END_IF;
4: output:=12;
IF inputtime=t#25sTHEN state:=0;END_IF;
END_CASE;
But this program is ok in Simulation Mode It change the State from 0 to1, 1 to 2, 2 to 3. 3 to 4.
But when I load this program in CoDesys SP RTE, then It runs but No chage of "state". That means "CASE... of " operation is not working.
I have need suggestion because i have to use this "Case..OF" state ment for CANopen State Machine to take in opeartion.
Thanks
Asif
PostPosted: Tue Oct 25, 2011 4:57 am
change the if case to >=...
IF inputtime>=t#5s THEN
then it works
cu
PostPosted: Tue Nov 01, 2011 6:20 pm
It is because the simulation checks the seconds but if you say time then it is in milliseconds. and as the program takes a few milliseconds to run the time is not exactly same but a little different.
so the solution is good and will work.
same is btw for almost all analog signals you will have to check the bounds.
for this state machine look at www.oscat.de
or have a look in SFC here you can do exactly same, as this chart is designed for this type of statemachines.
shooter@home.nl
computer shooter
paul deelen
jacob van wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
skype shooter paul.deelen
phone +31736139136
