It is currently Mon Feb 18, 2019 3:53 am
PostPosted: Tue Aug 25, 2009 1:45 pm
I need to launch and run after codesys bootproject a visual basic project.exe:
Is possible to launch by codesys an external program for example ".exe" of visual basic??
Regars
Stefano
 Post subject:
PostPosted: Thu Aug 27, 2009 7:57 am
Online
Yes, it's possible. Please have a look to the SysProcess.library (V3) or the SysLibOs.lib (V2) library. You can start an application from your IEC code by calling the function SysProcessCreate2 (V3) or SysCreateProcess (V2).
 Post subject:
PostPosted: Fri Aug 28, 2009 7:56 am
my codesys runtime is for target winXP and in the folder of the available libraries (\Lib_NTRT) there isn't SysLibOs.lib.
But SysLibOs.lib is in the folder \Lib_PLCWinNT so i add this library, use the function SysCreateprocess and build-all and it's ok but when i download the program to the target it shows the message "Unresolved external POU: SysCreateProcess _" :cry:
Regards,
Stefano
 Post subject:
PostPosted: Thu Sep 17, 2009 5:21 am
Check and make sure there is also a .hex file in the folder as well. It appears to be an external library instead of an internal library so it will need the compiled file.
Thanks,
Steve Pfeifenroth
 Post subject:
PostPosted: Fri Sep 18, 2009 11:50 am
I don't find any *.hex file.. can you send me the *.hex file that i have to compile?In which folder i'd to find the *.hex file?
regards
Stefano
 Post subject:
PostPosted: Fri Sep 18, 2009 4:18 pm
I do not have the realtime system. Sorry.
Thanks,
Steve Pfeifenroth
PostPosted: Wed Oct 02, 2013 2:54 pm
You can call a external program via the macro function during prebuild and post build:
Project -> Options -> Macro
- Define marcos. I have to use absolute path:
call $PROJECT_DRIVE$$PROJECT_PATH$\macro\PostBuild_exp_copy_wdatetime.mac
You can run a macro before and after build:
Project -> Options -> Build
Macro before build: prebuild.mac
Macro after Build: PostBuild_exp_copy_wdatetime.mac
In the macro you can make system calls:
in my PostBuild.mac:
;; this only copies the 2nd digit of the hour this will overwrite files -> %time:~1,1%
system copy $PROJECT_DRIVE$$PROJECT_PATH$\$PROJECT_NAME$.exp $PROJECT_DRIVE$$PROJECT_PATH$\$PROJECT_NAME$_%date:~-4,4%%date:~-10,2%%date:~-7,2%_%time:~1,1%%time:~3,2%%time:~6,2%.exp
PostPosted: Thu May 05, 2016 8:54 am
Hi, aes,
I tried with your macro code, but seems the path like what you wrote:
It doesn't work.
I have to use absolute path.
Do you know how to fix it?
On the other hand, do you have the macro command list of CoDeSys?
Because there is quite few information about macro in the manual.
For example, now I want to export just the Global Variables to EXP file.
But with my macro, my CoDeSys project always export the EXP file of the whole project.
Do you konw is there any way to get my need?
Thanks!
